cigarette lighter
Old Mar 23, 2001 | 03:15 PM
TMoNeE's Avatar
Car: 87 Z28
cigarette lighter
Hmm dont know where this should go but since i have a 305 TBI, its going here..
All i need to know, is there an easy way to take the cigarette lighter out.. not unplugging it, but taking it out of the plastic bracket.. seems like maybe its glued in or somethin
Old Mar 23, 2001 | 06:22 PM
Neo's Avatar
Neo
What year/kind of car?
Mike Kenny
1991 Chevrolet Camaro RS 305 TBI
My Website
Administrator at Auto-Clubs.net
My Baby
Old Mar 23, 2001 | 07:03 PM
TMoNeE's Avatar
Car: 87 Z28
my bad, 89 camaro RS
89 RS 305 TBI
Edelbrock 14x3 OE intake, Hypertech Chip, Street & Strip shift kit, flowmaster exhaust w/ high flow catco cat.
Soon: 3.73 gears, posi, Edelbrock TES headers(jet-hot) and a 355 SB
AIM:TiMoThY9801
Stereo:
JVC Detachable face cd player w/ 2 Pioneer 12" subs in custom box, powered by Lanzar 600 watt amp.
RIP #3 YOU RULED!
Old Mar 23, 2001 | 09:14 PM
Brentis007's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Transmission: Manual 5-speed
Axle/Gears: stock
Try taking the panel off and looking from behind. Why do you wanna take it out anyway?
Old Mar 23, 2001 | 10:50 PM
steve8586iroc's Avatar
You have to take the panel off and then unscrew the retaining ring from the back side.
Old Apr 16, 2001 | 08:05 PM
tropez's Avatar
I have the same problem on a '91 RS. The lighter housing is held in by a chrome "ring" on the front of the plastic dash panel. The ring seems to be press fit into the lighter housing on the back of the panel. I can pry on the assembly and loosen the ring from the housing but can't get it all the way off. Maybe I'm not prying hard enough? I find no nut on the back of the panel to loosen.
Thanks,
Scott
'91 Camaro RS
Old Apr 16, 2001 | 10:11 PM
Have you tried to unscrew it. I replaced mine on my 91RS and it unscrewed from the back. If you will look close you will see that the ring I mentioned is as long as the lighter housing it self. Just unscrew it but don't brake it buy trying to pry it off.
Steve
Old Apr 20, 2001 | 02:42 AM
JPrevost's Avatar
Car: 91 Red Sled
Yup, unscrew it, it's that simple.
, Jon (350 TBI! it's trenuous and efficacious while getting 23mpg highway with off the shelf eprom)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)AIM: JPrevost
  • Holley 670 TB unit w/ 1/2" spacer/adapter
  • Edelbrock RPM vortec intake
  • 350ho 330hp vortec crate motor
  • 8" harm. balancer
  • Stewart stage 2 water pump w/160 thermo
  • SLP tri-y headers to full 3"
  • Rebuilt trans w/ SLP shift kit
  • Centerline 16x8's all around
  • 36/24 mm sway bars
  • Full poly bushings, even motor mounts
  • SLP LCA and panhard
  • Alston SFCs
  • Edelbrock 3 point STB
  • Global west steering brace aka wonderbar
  • Eibach pro kit springs
  • Bilstien high perf. struts and shocks
  • All this and I still have AC
My websiteAny questions?
Old Apr 28, 2001 | 10:20 PM
MARKSREDZ's Avatar
Yep it unscrews, the back of the lighter housing unscrews from the the front(the chrome ring on the front). Sometimes it can be pretty tight but it does unscrew.
ZZ3Astro
Aug 13, 2019 12:57 AM
SlowAZ28
Members Camaros
Aug 31, 2015 07:53 PM
Moore89
Aug 24, 2015 07:06 PM
crazynights
Aug 21, 2015 06:53 AM
apie2546
Aug 8, 2015 07:12 AM
