Cam install questions (I've never done it before)
Old May 10, 2001 | 12:06 PM
MatthewH's Avatar
Since this swap is just starting you guys are going to get real tired of me fast
I am basically a newbie when it comes to internal engine work-I've done alot of other stuff with cars, but I've never touched a cam. Soon I'll be installing one into my 305 short block...HELP! First of all I've been looking at cams in Summit and found that Crane has their smog legal Compucams for $135, but the Summit brand cam with the same specs (not sure about lobe seperation though) for $79.99 w/ lifters and lube. Are there any major differences here or is the Summit product just as good? I've heard alot of good stuff about other products of thiers in the past.
So anyway if anyone has some tips/things to watch out for I'd greatly appreciate it...
Thanks,
Matthew C. Hall
Old May 12, 2001 | 09:33 AM
Vader's Avatar
Matt,
You should post this this on the Tech/General Engine Board, where you will likely get more advice.
Later,
Vader
"Fear is how I fall, Confusing what is real..."
Adobe Acrobat Reader
[This message has been edited by Vader (edited May 12, 2001).]
Old May 12, 2001 | 01:08 PM
Intense92's Avatar
MatthewH, Is your engine a 1988 or newer model, if it is the engine has a roller camshaft in it and they cost about $250.00 or more, but you can reuse the lifters if they are in good shape, I have a Crane 2020 compu-cam in my RS and it helped the power a lot.
92 Camaro RS 5.0 5-Speed
L98 Alu. Heads
SLP coated headers
Dynomax cat-back
14" open air cleaner
Old May 13, 2001 | 10:51 AM
EVILFACE's Avatar
If you can, see if you can locate a LT1 cam.
EVILFACE
88 Camaro
Stock 305 TBI Auto,Flowmaster, Full 3" Exhaust, B&M Megashifter
Runs A Blistering 16.5 @ 81.5 mph
http://www.evilface.com/evilscamaro.htm
Old May 13, 2001 | 01:21 PM
JPrevost's Avatar
Car: 91 Red Sled
Moving to General tech.
, Jon (350 TBI!)
91 Red My website
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
