Good Cam for 305 (L03)
Car: 88 Formula, 04 CTS-V, 06 Commander
Engine: 305 TBI, LS6, 4.7 V-8
Transmission: 5 spd, B&M Short Throw
I came across a real good (Jasper) L03 (3 y/o with only 20,000 mi.) that I am going to put in my '88 Formula 5-spd. I know I'll probably get the usual "just go 350" responses, but I was wondering what cam would be good for me. This car is my daily driver, and sees light traffic daily.
A few years ago I was researching cams and was lead towards the CompCams 262. I guess right now that would be my option, along with the ever so popular LT1 cam.
Any other thoughts, suggestions, etc?
Car: 89 RS
Transmission: th350
I had a comp 224/230XE in my first 305. I loved that cam. Nice idle but not tomuch for the street.
I dont know how that will work with your tbi tho i had a carb.
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
My cam in my 350 is almost exatly the same as that CompCams 262 and it's a pretty sweet cam. Sounds good, doesn't really need a stall converter (i'm sure one wouldn't hurt tho) and a pretty good power range!
Car: 1983 G20 Chevy
Transmission: 4L60
How much tuning are we talking? Will the ZZ4 work well in a 350?
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Youll have to redo the VE and spark advance tables as well as make sure your using a good fuel pump. Also, the heads may not take that much lift, so youll have to check that before you install the cam. Youll also need better springs and screw in studs. Might be easier using an LT1 cam or an old school flat tappet without alot of lift, or mod/replace the heads.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
