cam replacement
Old May 21, 2001 | 09:55 PM
91rscruiser's Avatar
cam replacement
ok heres the deal.i was pricing out a new valvetrain for my 91 rs 305 the other day and when i was looking at pushrods and lifters some of them said that they were not for use with 87-up small blocks with a factory roller cam.so i was wondering if i can replace the factory roller cam with a comp cams hydraulic cam,and all the other parts to go with it without any hassle.ive also noticed that there are even some timing chains and gear drives that wont fit the facotry roller cam.any help would be greatly appreciated.
-1991 camaro rs,dark red metallic,t-tops,stock 15inch rims
-stock L03 305,th700r4,only mod for now is a flowmaster 80 series replacement muffler.
Old May 21, 2001 | 10:54 PM
Tas's Avatar
Tas
unless you will be reving over 6500 RPM, the hydraulic roller cam is a superior design. If you want a cheap cam get one from an LT1, LT4, or L98. use they should be less than $50 and new should be $140 or more
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old May 22, 2001 | 08:59 AM
FastBroker's Avatar
I agree. GMPP has several roller cams that are nice and cheap, like the LT4 cam and the cam that they use in the RamJet 350, although that one is rather mellow. I'd like the LT4 cam in a 305... Very EFI compatible, too.
Fronzizzle
Mar 18, 2019 08:29 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
Fronzizzle
Aug 9, 2015 01:15 PM
