Swap from Carb to TBI???
Car: 04 Chevy Silverado 1500
Engine: V6
Axle/Gears: Stock
I don't know where i should of posted this, but this looked like the place,
My buddys said to Swap from Carb to TBI. How much would this run my $$$ and how hard would it be to do so?
Its a 1983 Firebird 2.8L V6
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
You could get the tbi setup off a 2.8 s-10. Finding everything at a junkyard should cost more than $100 (if you have reasonable junkyards near you). Then you'd have to buy gaskets and such, but it wouldn't be too hard of swap. You probably won't gain much power, but you'd have better drivability.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
you cant always listen to buddies
you have to do what ou want, not what others suggest you should
if the car runs fine how it is then i would leave it be
really.
save yourself lots of time and $$$ and headache
if they want ot see your car be a TBI one then maybe they should buy the car off you and then they can attempt it
good luck
really.
good luck
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
If you decide to F.I. it, I would at least get a more modern ECM/PCM, otherwise, like stated above, it's not really worth it.
Better yet, explore non-OEM options. Such as www.megasquirt.info
I own a MSII/V3.0 and it is currently running my TBI(prev. carb) Camaro.
