could a 1/2 " spacer do this to my new 350?
I was gonna post this on snflu's post re spacers but it may be a different subject. Anyway, I got 300 miles on the new 350 and it has been doing great. Today I noticed that with the new manifold, my air cleaner was rubbing slightly on the hood so I decided to remove the 1/2" spacer.
The car ran like s*** seemed to miss, load up etc and surged at idle from 500 to 1500 RPM.after about 10 miles the idle came back
and it ran ok. Did the computer adjust to this change?.
How could the spacer make this difference?
Did I do something else? Could it be the TPS
got out of adjustment?
My GM tech friends couldn't figure it out and thought for sure I had a vaccum leak but we checked and all was fine. It also seemed to lose a lot of torque off idle.
I put the spacer back on and it definitly idles more consistent and has better off idle torque but I can't believe just removing the spacer could cause all that problem.
Is there another explanation than just the spacer? Sure appreciate any thoughts you all may have..........bob
91 camaro RS convert,GM crate 350 with LT1 cam,edelbrock 6085 heads,9.5:1 comp, edelbrock TBI intake, 65# injectors, GM cop chip,dual fan conversion,
ultimate TBI mods,TBI spacer,SLP 1 5/8 headers,
3"cat back,Flowmaster,
T-5, centerforce 2 clutch, 3.42 torsen posi,alston SFC's,Global West LCA relocation brackets, edelbrock STB
Car: 91 Red Sled
Something isn't right, a spacer should do next to NOTHING. I've asked before about spacers and they're used only to fine tune an engine. The real plus is the heat shield, nothing more. Check for vacuum leaks and everything else, sounds like you have some serious problems.
, Jon (350 TBI!)
91 Red My website
, Jon (350 TBI!)
91 Red My website
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
