Lobe Seperation Angle
Old May 29, 2001 | 05:18 PM
iroc22's Avatar
Will a 110 degree LSA hurt the TBI and it's computer? I'm doing a camshaft swap and I want to know.
Old May 29, 2001 | 05:40 PM
JPrevost's Avatar
Car: 91 Red Sled
What are the specs on the cam other than lobe sep. I know you want a higher number with efi. I think 110 might be okay. Hopefully some of the cam guys here can tell you if it'll work well of if it's going to be a PITA to tune.
, Jon (350 TBI!)
91 Red My website
Old May 29, 2001 | 07:55 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
ive heard 112-114 is perfect for our cars.
Old May 29, 2001 | 09:58 PM
iroc22's Avatar
yeah I heard the same thing but its a comp cams camshaft and they only have the 110 LSA for all their flat tappet cams
Old May 30, 2001 | 12:29 AM
rsilver's Avatar
from what I have read here, most people say you should not go with less than 112 LSA. I understand that some people have used 110 LSA cams but you will have to do a custom chip to live with it but you will probably do that anyway.There are a lot of posts dealing with this so check the archives and read up before you spend your money.......bob
Good luck...........bob
91 camaro RS convert,GM crate 350 with LT1 cam,edelbrock 6085 heads,9.5:1 comp, edelbrock TBI intake, 65# injectors, GM cop chip,dual fan conversion,
ultimate TBI mods,TBI spacer,SLP 1 5/8 headers,
3"cat back,Flowmaster,
T-5, centerforce 2 clutch, 3.42 torsen posi,alston SFC's,Global West LCA relocation brackets, edelbrock STB
Old May 30, 2001 | 07:53 AM
FastBroker's Avatar
IROC, I ran a Comp XE250 with TBI and it ran AWESOME!!! It is a rather mellow cam, though, so the 110 lobe sep did not hinder with that cam. only 206/212deg .050" duration... Comp DOES MAKE 112 and 114 flat tappet cams. Go to there website, HTML version of the catalog and pages 56-57. You'll see them there. Oh, compcams.com...
Once you get into bigger durations, IMO you will ned 112+ lobe seps but for mellow cams, 110 is fine! Unless a 350cid with 320+hp and 400lb-ft+ is not enough for you, that is...
Old May 31, 2001 | 01:59 PM
iroc22's Avatar
that's awesome I hope that the 110 LSA won't screw up my TBI. I'm going to get a new chip with it. I didn't know Comp Cams made 112 and 114 LSA cams! i guess you learn something new everyday
Old May 31, 2001 | 02:19 PM
FastBroker's Avatar
That's just the catalog stuff. They can make ANYTHING you want. Just goe with a smaller duratoin cam and the overlap won;t hurt you. You can compare the overlap or lack or overlap (exhaust and intake open at the same time OR not) of the cams (at .050" lift) by using the spec sheets. That's what I do but it takes time. Goof for apples to apples comparisons of cams made by different cam mfrs.
Good luck...
[This message has been edited by FastBroker (edited May 31, 2001).]
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Jorlain
Oct 8, 2015 01:57 AM
skinny z
Oct 5, 2015 06:23 PM
mfp189
Sep 27, 2015 09:25 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
