454 injectors too big?
Old May 29, 2001 | 10:34 AM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
I recently ordered some injectors from GM using a part number off the archives here on thirdgen, thinking that they would be the yellow/brown Caprice police cruiser injectors. Instead I got the blue 454 injectors. Will these still work on a 350? I'm using a stock TBI unit, and will be making close to 300 horses, maybe a little more. My dealer charges a 20% return fee for special order parts, so I'd like to use them if I can!
Old May 29, 2001 | 11:11 AM
Dan W's Avatar
Yes, they can work.
They are not exactly perfectly sized.
They are not plug and play.
Some minor custom programing will be required to make them work in the car.
1988 T/A,
9" Ford, 3.50 gears, Auburn posi, 700r4 -w- 2100 converter, 360ci, 9.8:1 cr,
AFR 195 Heads, Weiand #7525 intake, Lunati roller 219/227, .479/.480, 112 LSA
Holley 700cfm 4bbl on TBI truck 7747 computer and chip by Howell-EFI
Old May 29, 2001 | 11:43 AM
Brent's Avatar
What part number did you order? We should correct the archive.
Old May 29, 2001 | 11:44 AM
JRoy91RS's Avatar
Engine: 355
BTW, if anyone knows the CORRECT p/n for the caprice injectors, please, please let me know. I think that I'm going to go with them, since I already have a caprice chip
thanks
Old May 29, 2001 | 12:10 PM
JRoy91RS's Avatar
Engine: 355
I'm pretty sure the P/N I used was 17112560 from snuf's injector chart. Check the archives. I'm not completely sure that this is the number I used, but I will check when I get home.
Old May 29, 2001 | 12:58 PM
FastBroker's Avatar
If they are too big for you, I'll buy them off of you if unused with warranty.
Old May 29, 2001 | 02:44 PM
Brent's Avatar
My notes show the 65lbs/hr Police injectors as part# 17112412. I believe the regular Caprice 55lbs/hr units are 17112493. You probably want to double check this at the dealership.
Old May 29, 2001 | 02:47 PM
FastBroker's Avatar
Snuf, wudyou do?
Old May 29, 2001 | 04:14 PM
JRoy91RS's Avatar
Engine: 355
Fastbroker, I would want way more than you want to pay for them (most likely). If you can get me the caprice police injectors, I will definitely swap even.
Old May 29, 2001 | 06:38 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
uuhhhhhhhhhh?
how about we find out what the number is before we say its my fault. besides, i just went by what my parts guy gave me
wait a minute, i just checked, i dont even have that number labeled in my delco catalog.
which means, if thats the number from the chart, it was derived from somewhere else, from another chart that was partial etc..
thats not MY chart guys. its a comilation
but im sure you will be able to find a buyer if you cant use em.
Old May 29, 2001 | 07:37 PM
JRoy91RS's Avatar
Engine: 355
Hey snuf, I didn't mean to implicate you in any wrongdoing. You've answered a lot of questions for me before, and always given some of the best advice on the board. I was just letting people know where they could find the chart in the archives so they know to watch out. I'm not peeved at all . I realize that things like this happen. Mistakes are made. In fact, it's my fault for not double-checking. So, if anyone wants to swap me some Caprice injectors for some 454 ones, e-mail me. I'll swap ya' even. They're brand new.
Old May 30, 2001 | 02:25 PM
TBImaster's Avatar
Normally I wouldnt say anything.
I dont know p/n's but most caprice 350's came with 61lb injectors.
55lb injectors can support 280hp after that BPW and injector cycle is 100% (which is bad). These are in all 305's
61lb injectors can support 360hp(same applies from above). These are in caprices
65lb injectors can support 400+hp
These are in most COP cars and trucks
68lb injectors can support alot of ponies.
These injectors are only in 454's.
Do you really need bigger injectors???
Old May 30, 2001 | 02:47 PM
Brent's Avatar
<font face="Verdana, Arial" size="2">Originally posted by TBImaster:
</font>
You left out the fuel pressure thats required to make that much HP. Those injectors mentioned will not support the numbers listed without increased FP.
Old May 30, 2001 | 03:00 PM
TBImaster's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Brent:
You left out the fuel pressure thats required to make that much HP. Those injectors mentioned will not support the numbers listed without increased FP. </font>
Your right.
The 55lb can handle 18psi before your screens tear sometimes earlier.
61lb I've had mine to 15psi on 330hp easy
65lb Which I've used still set at 15psi seemed to be overkill. They were cycling at only 65% WOT
Now the 68's and 80's were used on big blocks by truck guys so I could'nt tell you w/o lying.
Old May 30, 2001 | 03:05 PM
JRoy91RS's Avatar
Engine: 355
I was under the impression that the 454 injectors were 80 lbs. Now I'm really confused. If mine are only 68, then according to those above numbers, there's really not much difference between the 454 and the cop injectors. ??? Can someone help us out?
Old May 30, 2001 | 03:11 PM
Brent's Avatar
How did you make 330hp with less than 75lbs/hr per injector?
I'd like to see the BSFC sheet on that engine.
Old May 30, 2001 | 03:12 PM
TBImaster's Avatar
<font face="Verdana, Arial" size="2">Originally posted by JRoy91RS:
I was under the impression that the 454 injectors were 80 lbs. Now I'm really confused. If mine are only 68, then according to those above numbers, there's really not much difference between the 454 and the cop injectors. ??? Can someone help us out?</font>
The 80lbers came in the Holley TBI.
And yes the 454TBI came wih 68lbers
and there is a difference between 65 & 68
One being pulse rate and secondly cycling duty is lower for 68 on the same engine.
Old May 30, 2001 | 03:20 PM
TBImaster's Avatar
</font>
I have my dyno sheet somewhere.
it was 330.6hp/374.8ftlbs torque
There was no build sheet. Just worked overed frankenstein parts.
Old May 30, 2001 | 03:22 PM
JRoy91RS's Avatar
Engine: 355
So what would happen if I used the 454 injectors with a caprice cop chip? Would this be disastrous?
Old May 30, 2001 | 03:23 PM
JRoy91RS's Avatar
Engine: 355
Sheesh. Someone's gotta have the right part number for the Caprice cop injectors. Does anyone out there have a set they want to let go?
Old May 30, 2001 | 03:28 PM
Brent's Avatar
Brake Specific Fuel Consumption
It will be listed on your dyno sheet. I'm curious as to the bsfc numbers around peak torque and around peak horsepower.
Old May 30, 2001 | 03:29 PM
TBImaster's Avatar
So what would happen if I used the 454 injectors with a caprice cop chip? Would this be disastrous?</font>
No. The chip really doesnt alter that much.
Its just the same as the 305chip just with a little different fuel/timing curves. no biggie.
Oh yeah the motor was out of the car when it was dyno'ed. So do the math on rear wheel hp.
Old May 30, 2001 | 03:55 PM
JRoy91RS's Avatar
Engine: 355
So it would be ok then? To use the 454 injectors with the caprice chip? What would be better?
Old May 31, 2001 | 12:09 AM
GhoSSt's Avatar
I've got a 454 TBI with Caprice injectors that I want to sell, but I want to get 200.00 for it.
Its in great shape.
Kelly 'GhoSSt' Rosato
1996 Impala SS, 383 LT4 (14.65 up here, 13.24 lower)
1984 Firebird, +.060 350 (Vortech Heads, HOT Cam, and schtuff)
1993 Caprice, 5.7 TBI (stock . . . FOR NOW)
"And if you wrong us, shall we not revenge? Revenge. The villany you
teach me, I will execute, and it shall go hard but I will better the
instruction."
Shylock in Act III, Scene I of 'Merchant of Venice' by William Shakespeare
Old May 31, 2001 | 08:06 AM
FastBroker's Avatar
If you use 80pph injectors with an OEM chip on a 350, you're in big trouble unless you turn your FP waaaaaaaaaaay down. You need at LEAST a 350hp motor to be able to run those injectors and, even then, can only run them with a custom PROM.
As far as I can tell, 55pph injectors came on GMC/Chevy 350cid pickups, not 65pph injectors, BTW.
Old May 31, 2001 | 09:07 AM
JRoy91RS's Avatar
Engine: 355
But I thought the GM 454 injectors were 68 lb.???? This doesn't sound too far from the caprice cop injectors at 65. BTW, I'll be using a hypertech chip for a caprice cop car.
Old May 31, 2001 | 12:47 PM
Brent's Avatar
I don't when 68lbs/hr units were used in the BBC.
I do know these were used in the BBC. THe flow test ran at 10psi.
Late 17112560 Blue/Black are 75lbs/hr static
Early 17111784 DrkRed/DrkBlue are 90lbs/hr static
Credit goes to W. Sherwin for flow testing.
Old May 31, 2001 | 05:07 PM
prscarf's Avatar
i have a 454tbi on my truck which is brand new from gm and they have the blue/black color codes for 80lbs.
Color code Application Flow rate part #
Black/White 1-3/8" bore 2bbl, from 2.8l truck ??? GM 5235430 *RPD
Yellow/Blue 4.3L ??? GM 5235203 *RPD
Green/White 5.0L 40 lb/hr GM 5235279 *RPD
Orange/Black 5.7L pickup 55 lb/hr GM 5235206 *RPD
Yellow/Brown 5.7L Cop Car 65 lb/hr ???
Blue/Black Late big block pickup 80 lb/hr GM 1708430 *RPD
Dark Red/Dark Blue big block pickup 90 lb/hr GM 5235231 *RPD
hope this helps.
i tuned my 383 to a 120bpw, i found 115 to be lean at mid range.
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Ranbo108
Sep 9, 2015 12:20 PM
