my 92 RS 305 TBI, what will she run ???
Next week i am heading to the drags for my first runs down the track, i was just wondering what kind of times i can expect, and also what HP might she be putting out ?
Its a 92 RS 305 TBI with about 50,000 miles
My MODS are as follows
1) Open Element 14 x 3 K&N
2) Advanced timing to 6 degrees
3) AC Delco Rapidfire plugs
4) Blue Max 8mm plug wires and MSD cap
5) B&M shift kit
6) 3.23 gears
7) Dynomax Super Turbo cat back system
8) Gutted Converter
many more mods to come, i did all the cheap stuff, next is cam, headers, chip, and heads, but for now its good enough, thanx guys
5) B&M shift kit
6) 3.23 gears
8) Gutted Converter
Car: 91 Red Sled
Low 16's is my prediction. That is going to be the best time (unless you're below sea level!). You did about 1.5 out of 3 things you need to do with the Lo3. First, I like the open element, good move. The worst things about the Lo3 are: exhaust, heads, cam, intake (pretty much everything). headers are the best investment in my opinion. I like that you did gears but did you go with a posi unit and I would have done 3.42 at least. Anyways, you're next mod should be either an intake manifold or headers/y-pipe. Those really kill the car. If you want to go below the valve covers, 1.6 rockers could help. Good luck and have fun, don't expect the car to do 15's unless you have some mad skill and traction.
Moving to drag racing board.
, Jon (350 TBI!)
91 Red My website
[This message has been edited by JPrevost (edited June 05, 2001).]
, Jon (350 TBI!)
91 Red My website
