Is the stock intake even worth messing with?
Old Jun 6, 2001 | 08:48 PM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
I've heard of guys boring out their stock intake throttle bores (to facilitate use of 454 TB) and porting them, and was wondering if this was even worth it? I know that most people recommend a carb intake with the Holley spacer, but I am afraid of not getting the linkage to hook up properly. Can the stock intake perform just as well if ported properly? Thanks guys.
Old Jun 6, 2001 | 09:12 PM
NJ SPEEDER's Avatar
if you don't have the cash for an edelbrock intake to open up the holes in or a holley intake(already has the 2in bore holes) it is worth it just to help the flow. if you have money for an aftermarket intake i would suggest you invest in one.
lata
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Jun 6, 2001 | 09:57 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
"if you don't have the cash for an edelbrock intake to open up the holes in "
What do you mean by that? That you can bore out the edelbrock intake? I thought you couldn't.
Old Jun 7, 2001 | 12:17 AM
firbird's Avatar
i think that he means that you can by an edelerbrock intake that is already bigger so you do not have to port it
Old Jun 7, 2001 | 12:29 AM
JPrevost's Avatar
Car: 91 Red Sled
The edelbrock is 1 11/16, not 2". Tim said it right, he was talking about getting the Holley projection intake. That has the 2" bore for the holley 670 TB unit. I would have gone with that intake if I hadn't had the vortec heads. You should really think about the holley intake, it's really good and setup for everything, including EGR. I wouldn't worry about the throttle linkage, that is the "fun" part about doing engine work. Heck, I have a zip tie right now holding my throttle to my linkage! Not the safest thing in the world but I check it ALL the time and it's been fine. I have the edelbrock RPM with holley adaptor.
What engine are you going to put the 2" unit on? If it's a 305 with anything less than 300hp I don't sugest it. The stock unit can be made to flow well (~550cfm) and even right now my friend is running a 327 370hp monster with a 600cfm double pumper! Runs high 12's so realistcally the 2" unit isn't worth the effort. I have the unit but I also have 45 more cubes than most and it just happened to come with the 65# injectors I needed . Long live TBI!!!
, Jon (350 TBI!)
91 Red My website
Old Jun 7, 2001 | 07:55 AM
JRoy91RS's Avatar
Engine: 355
I would be putting the 2" unit on a 350 that is currently sitting in my car. I swapped it in a few months back, had hell with a TPI swap (Long story), so I decided to stick with TBI. Anyways, I ordered 80# injectors by mistake, so I need the 65#. I already have the Edelbrock TBI intake, which I got because it seemed the most user-friendly. Now I'm regretting my decision in case I want to upgrade to a 2" bore unit. What should I do? I have all this stuff I don't need. Fortunately, it's all new, so it's returnable. To be honest, I'd rather sell it to someone here. So it's pretty much a consensus that the stock intake sucks (no pun intended), right?
1992rs/ss
Jan 31, 2025 05:10 PM
italiano67
Dec 11, 2016 09:21 AM
draco
Oct 4, 2015 09:25 PM
Streetstuff
Sep 7, 2015 09:23 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
