I have what u call.... A PROBLEM!
Old Jun 8, 2001 | 11:09 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Went to go time my car tonight with the G-tech and these problems happened.
#1. Lined my car up, went to floor it and I saw an explosion of fire inside my open element and the car instantly stalled out. But it started right back up and ran like it did before, but it has been doing that on and off lately and its only when I floor it or give it 3/4 throttle from idle.
#2. Lately I have also been hearing a ringing at idle. Maybe it rings at higher speeds but I can't tell because of my exaust noise.
#3. When I am G-teching the car, it seems to loose power at around 45mph. I am thinking maybe my fuel pressure needs to be boosted because there is more air coming in that 14x3 open element from my ram air hood, but its just a guess.
SOOOO...these are my problems. Is my timing bad one way or the other? Thats my guess. I would go in the garage and check my plugs but the garage is full right now.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Old Jun 9, 2001 | 09:21 AM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
My throttle body would set on fire also when my fuel pump went bad and i wasn't getting enough fuel. This usually happens becuase of a lean condition so i would think that you need to increase your fuel pressure. You've already opened up your exhaust and intake, so a little extra fuel would be good, i think.
Pat Hirsz
www.iit.edu/~hirspat/MyPage2.htm
88 305TBI
Mods:Hooker Aerochamber 3" exhaust, no cat,SLP 1 5/8" headers and y-pipe March pullies, no smog, 180 thermo,
14x4 K&N, 3.42 gears(open), Ultimate TBI Mods,AFPR,MSD(ignition,coil&wires),Edelbrock TBI Manifold, 190ltr/hr fuel pump,
Eibach springs with KYB's all around,
Harwood cowl hood, Z-28 wing, fresh paint(black)
120,000 miles, 5spd, T-tops
0-60mph-7.2s-Gteched
92 RS, 305TBI, auto, 3.08 gears, 180 thermo, glasspack (no muffler)
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
