Carb To TBI Swap
Old Jun 4, 2001 | 01:03 AM
CamaroLuvnPunk's Avatar
Carb To TBI Swap
So I have all the TBI Parts..... Computer included. However I need a book or something for this...... cause I don't want to swap the engines out...... I just want to swap the TBI stuff on to ****ty Carb.
Any help would be great.....
Thanks,
Erik
Old Jun 4, 2001 | 03:39 AM
JPrevost's Avatar
Car: 91 Red Sled
If you have all the sensors then you're set. You just need to invest in a $45 adaptor plate from holley. TBI to either square bore or spread. You'll need a knock sensor (passengers side of block), CTS (intake manifold near thermo housing), you DON'T need an IAT (read about it in the tech article, I forget what resistor you put in it's place), oil pressure, an electric fuel pump is best (low flow pressure), a MAP sensor, and an O2 sensor. When you get all that stuff onto your carb enging make sure you're running open element , it's the only way to go. What are the specs on the engine? If your cam is less than 112 lobe seperation you're going to have a *itch of a time getting TBI to work well. What kind of trans do you have and gears? Please be more specific.
You'll want to make sure to plug up all the vacuum ports on the TBunit that you don't need. When you hook up the MAP sensor you'll want to be sure to have it on a "ported" vacuum fitting. If you visit my website I just updated it and have a section that explains where to find/install all the sensors.
Hope that helps.
, Jon (350 TBI!)
91 Red My website
[This message has been edited by JPrevost (edited June 04, 2001).]
Old Jun 4, 2001 | 08:11 AM
FastBroker's Avatar
He needs a NON-PORTED connection to the MAP sensor!!! ie, direct engine vacuum at all times!!!
Old Jun 10, 2001 | 12:54 AM
Hey,
I have a 1983 Camaro 305 with Carb. I have EVERYTHING TO the TBI setup. I have a 700R4 Trans and 3.08 Posi gears..... anything else let me know.
I need help with this. Also where can I get a Dual TB setup?? I have heard of this but never seen it.
Erik
1983 Berlinetta Camaro with a 305 4brrl Carb.... soon to have a bigger carb,intake, and cam.
Old Jun 10, 2001 | 01:39 AM
JPrevost's Avatar
Car: 91 Red Sled
FB, http://www.crosswinds.net/~jprevost/...bels/index.htm
This is ported isn't it? It always gets vacuum. Non-ported was near the TBunit. At least that was what I gathered. Anyways, the lable "ported vacuum" might be wrong but that is where you want the MAP hooked up.
, Jon (350 TBI!)
91 Red My website
[This message has been edited by JPrevost (edited June 09, 2001).]
Old Jun 10, 2001 | 12:27 PM
Hey,
What performance parts can get you get for TBI?? I have found bigger injectors and a computer chip. However thats all I found. Any help would be great.
Erik
1983 Berlinetta Camaro with a 305 4brrl Carb.... soon to have TBI,Electric Fan, Serpintine Pulleys and if I can find one... a LT1 Cam.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
