Holley TBI adapeter plate-which way does it go on
Old Jun 11, 2001 | 10:03 PM
rsilver's Avatar
Is the adapter supposed to mount the TBI so it is foreward of centerline on the manifold or so it is behind the center line of the manifold? Does it make a performance difference and if so why?
Thanks for the help on this..........bob
91 camaro RS convert,GM crate 350 with LT1 cam,edelbrock 6085 heads,9.5:1 comp, edelbrock TBI intake, 65# injectors, GM cop chip,dual fan conversion,
ultimate TBI mods,TBI spacer,SLP 1 5/8 headers,
3"cat back,Flowmaster,
T-5, centerforce 2 clutch, 3.42 torsen posi,alston SFC's,Global West LCA relocation brackets, edelbrock STB
Old Jun 11, 2001 | 10:29 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I ain't ever done it, but it would seem that performance wise, it'll make no diff. It's like putting a 2v carb on a 4v manifold anyway. I mean, it's better than that, but the same concept. I would recommend putting it forward just for better aircleaner-to-distributor clearance. Unless you run into another clearance problem up front. Just loosly put it all together w/ aircleaner to check. Try it both ways. See which works better.
92 RS w/t-tops 305 TBI Auto.
170K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford 2ch. to 2 MTX 12" subs
Old Jun 12, 2001 | 05:38 AM
JPrevost's Avatar
Car: 91 Red Sled
If you have a dual plane manifold it won't matter as much as a single plane. One thing you have to think about is how at low/part throttle the blades flow air to the rear cylinders by design. It's just the way they open and direct the air. With that in mind, you'll want to move the TB up front more for a street car. Center is best from a performance stand point. Definatly don't put it back more then center.
, Jon (350 TBI!)
91 Red My website
[This message has been edited by JPrevost (edited June 12, 2001).]
cowansauto
Apr 3, 2025 12:51 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Magman
Sep 14, 2015 01:30 AM
Glowsock
Sep 11, 2015 11:09 PM
