454 tps/iac/throttle linkage
Old Jun 13, 2001 | 06:25 PM
rsilver's Avatar
Does anyone know if the tps/iac/throttle linkage on the 454 TB is the same as on my 91 305 TB? I know there are some differences in 454TB's depending on the year but If I want to convert to the 454, can I still use the tps etc from my existing 305 TB ? What year 454 TB will work?
I tired the archives but couldn't find a clear answer./ Thanks for the help........bob
91 camaro RS convert,GM crate 350 with LT1 cam,edelbrock 6085 heads,9.5:1 comp, edelbrock TBI intake, 65# injectors, GM cop chip,dual fan conversion,
ultimate TBI mods,TBI spacer,SLP 1 5/8 headers,
3"cat back,Flowmaster,
T-5, centerforce 2 clutch, 3.42 torsen posi,alston SFC's,Global West LCA relocation brackets, edelbrock STB
Old Jun 13, 2001 | 06:52 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
no they are not the same. yes the tbi will work, but it will require rewiring.
Old Jun 13, 2001 | 09:58 PM
rsilver's Avatar
does anyone know if my 91 style small block TPS and Iac will bolt/screw in to the 454 TB? I was just going to order the base and use my injector pod........bob
Old Jun 14, 2001 | 01:50 AM
snflupigus's Avatar
you will have to get the 454 tps. ill take pics of em both and post em for you if you want. they are completely different.
Old Jun 14, 2001 | 02:05 AM
snflupigus's Avatar
you have to type this into your address bar, and then it only might work.
http://snflupigus.tripod.com/misc/sbnbbtps.jpg
DO NOT CLICK THE LINK, IT WONT WORK.
o, and i left it at high resolution so just in case you have any trouble seeing, they are very different.
[This message has been edited by snflupigus (edited June 14, 2001).]
Old Jun 14, 2001 | 10:07 AM
rsilver's Avatar
SNFLU, you are da man. I am gonna look at the pictures right now. Thanks for making that possible...........bob
Old Jun 14, 2001 | 10:21 AM
rsilver's Avatar
snflu,I checked the pictures. Man, that really helped. Do you know what year the Big block TB is in your picture? The reason I ask is I read a post where the later Big blocks (after 91) had the same tps and Iac as the small blocks.Thanks for all of your help on this...........bob
Old Jun 14, 2001 | 01:28 PM
snflupigus's Avatar
i guess that may be. but i guess you would have to ask these guys.
http://www.454ss.com
my delco/gm catalog doesnt have detailed pictures.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
budowski
Carburetors
Oct 2, 2015 10:16 AM
mfp189
Sep 27, 2015 09:25 AM
IROCNParts
Sep 24, 2015 10:50 AM
Mongoose462ci
Sep 16, 2015 11:46 PM
