rough idle for 2 min
Old Jun 20, 2001 | 06:20 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Got a friend with a TBI, and for the first two min it runs kind of rough. Does not matter if engine is cold or warm when started.
87 Formula 5.1 converted to TPI Yellow/Black
SLP Dur 206/212, Lift 480/487, Cent Line 112 cam, SLP headers, SLP cat-back exhaust
K&N Airfilter
Modified Stock cold air intake
Ported & polished Stock TPI intake
Holley Adjustable Fuel Press regulator
AC Rapidfire Spark Plugs.
Gil Younger (no yo-yo) Shift Kit
Aluminum Driveshaft
3.73 Posi gear
Baer 12" brakes 4 wheels
KYB AGX Adjustable Shocks & struts
Hotchkis strut tower brace
South side machine frame connectors
Custom reinforced control arms and pan hard bar.
Custom Leather interior
CUSTOM Yellow Gauge Faces
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
Old Jun 20, 2001 | 08:43 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Give it a tune up and daignostic check to look at all the sensors. Your problem could be caused by many things........doing this should help you narrow it down.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
