I guess I'm buying a new AFPR...
Old Jun 24, 2001 | 02:42 PM
92fire-audio's Avatar
I decided today to try and do the AFPR mod from this site.. I got everything going fine until I had to drill it.. The part that holds the bolt and cover came free and the tabs are either bent or broke and I can't get it to stay in place.. It simply comes out when I flip it upside down.. I have a feeling this isn't good.. So I guess I'll just order one from summit...
Oh well, these are they type of things that tend to happen to me while i'm working on parts that I need in the car....
Old Jun 24, 2001 | 03:27 PM
Well, I held it in and twisted it and it seems to be OK now, its in place and hard to move so I put it back in with an increase in pressure.. I fired it up, don't see any leaks but I am still a little cautious with it..
There doesn't seem to be any gasket on it in the first place, so it's not possible for fuel to leak out of the thing that holds the bolt, is there?
I just get a little nervous when i'm working with fuel systems...
Old Jun 24, 2001 | 05:36 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
fuel is never in the cup.
so if the round bottom of the cup came off, it wouldnt make any difference except it would be hard to adjust the pressure.
if you can tack weld it back on, or even a new actual nut back on that fits the threads of the little disc that holds pressure on the spring, youll have made your own perfectly usefull and as good as a 40$ peice from summit.
Old Jun 24, 2001 | 06:28 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Mine fell out.......I used the dremel to put the gash in the head so I could turn a screwdriver on it and it went back together well and forked fine.
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
Old Jun 24, 2001 | 07:08 PM
Its the part that is on the very bottom when everything is put back together.. It seems to be running fine and I don't see or smell any fuel but i'm afraid that i'll hit a bump and it will be shot completely open by the spring. Maybe i'm just paranoid.
Glad to hear that no fuel runs through there though. I think i'll wait on some of the other mods to my TBI unit until I can get my exhaust and gears done.
Old Jun 27, 2001 | 09:27 PM
Vader's Avatar
Check this for ideas:
TBI AFPR. It's a *.PDF file, so you'll need Adobe Acrobat Reader to open/view/print the file (See link below).
Later,
Vader
"Let the bodies hit the floor!"
BumpaD82
Feb 26, 2016 02:57 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
gta892000
Sep 16, 2015 12:37 AM
TOMcat GTA
Sep 15, 2015 09:31 AM
Jlanz55
Sep 8, 2015 11:28 PM
