what cam???
Old Jun 23, 2001 | 12:06 PM
buddman91rs's Avatar
what cam???
i know the specs on the stock cam in my 91 LO3. im not a perfessional when it comes to camshafts.....what should be the specs for a new cam? i only have a 14X3 OE and a custom exhaust setup that includes no muffler and a resonated tip...... any help would be greatly appreciated
Old Jun 23, 2001 | 02:53 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
even though your engine is mostly stock i would say to put in a lt1 cam and well as lt springs and you will definitly feal the difference
91 camaro RS
- 305 TBI
Mods: Performer TBI intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter, b+m trans cooler, white guage faces, megashifter..
next month: spohn LCA's and panhard rod, BMR relocation brackets, 323 gear, lt1 cam , 350 heads
Old Jun 24, 2001 | 11:34 AM
where would i go about finding this famed LT1 cam? how much would it cost? does anyone know what the specs on it are?
Old Jun 24, 2001 | 03:30 PM
Mike92's Avatar
I depends what year and what bodystyle. The impala had less duration than F-body and Vettes. But go to Scoggin Dickey or Jim pace and one of them will have it. It is a good cam though, the impala one will give a little more down low but not as much top end. I would get a F-body or Vette one. But go to those sites and I know one of them has some factory cams. You may want the LT4 cam, go look.
1995 Polo Green Vette, Auto, Almost Stock.
Old Jun 24, 2001 | 08:10 PM
JokerRS's Avatar
Car: 92RS
Engine: 357
I bought a used one cheap from the for sale board at http:// camaroz28.com .You see them all the time for $30-$50.Its working fine even with the stock chip.
Dave
92RS LO3 700R4
open air element
ultimate TBI mods
LT1 cam
Edelbrock TBI performer manifold
180 thermostat
Hooker headers
3"cat back
Zexel Torsen posi with 3.42 gears
Old Jun 25, 2001 | 08:24 PM
would a higer duration number give me a more "rumpity" idle? or is it the other end around? i would like to gain power across te rpm range..most down low but i do want to be bale to rev past 4 grand without it being all bark and no bite.....
Old Jun 26, 2001 | 11:47 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
The lobe separation is mainly what causes the rougher idle and the computer doesn't like that. Don't try and run anything with less than 112* lobe separation. I run a Compucam 2050 in my truck which has the 112 degrees. It has a mild lope and causes the computer to try and compensate with the idle. So my idle can be anywhere from 600 to 1200. But it does run well besides that. If you drop below the 112 your car may stall on the dips.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar
*Alston SFC's
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
Old Jun 26, 2001 | 11:06 PM
thats exactly what i want, er what i mean by rumpity....just generally something to scare the **** out of ricers cause my car is shaking back and forth from the idle i love that.......my da had a souped up 68 stang the had the wildest cam form crane that was still street legal and the thing was a beast......he said i always had a smile on my face in that car and i still crack a smile everytime my car gets warmed up and its sitting at 600 rpm idling and shaking back and forth a little bit....plus its for the ladies too
Old Jun 27, 2001 | 10:21 PM
Keith5's Avatar
Car: C1500
I can get my camaro so shake like that, but I fixed that vacuum leak.
1989 Pontiac Firebird Formula LO3 Auto
-180 degree stat
-Hooker Cat-Back
-velcro t-top bag
-Wonder Bar from my IROC
IAT MOD, 3.3ohm resistor
*****Possible future mods*****
4th gen seats, fiberglass spoiler, new paint
1985 IROC-Z, TPI Auto
-Accel Super Coil
engine and tranny overhauls coming this summer
http://www.geocities.com/krt80/
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
