TB unit limits
Old Mar 16, 2007 | 08:19 AM
86firebird350's Avatar
Car: 91 GTA
Axle/Gears: stock
TB unit limits
i was wondering what the limits are, as far as cfm goes, on the stock TB unit and the max hp they are good for? i was wondering the same thing for the 454 TB unit. i need to know b/c im building an l03 for 300+ hp and ive been told that TBI cant support that much. is that just with the stock TBI unit or is that with all TBI?
Old Mar 16, 2007 | 11:58 AM
cranknrods's Avatar
Car: 92 RS
Engine: 350vortec
take your throttle body and do the ultimate TBI mods. then bore it 48mm and use TPI throttle blades. your gonna need an AFPR and a stronger fuel pump. i would use atleast copcar injectors-then your gonna need to learn to burn chips but to answere your question-yes it is possible
--the cfm of anything being ported is directly related to the "porter"
as for how much horse power these TBI's can handle-their is no definite answer cause so many other things come into play. theirs the theoretical answer that uses formulas to determin how much air + fuel is needed for a certain HP but that will only get you in the ball park
but you can look up FAST355 and read some of his post and adventures and it a give you a better idea
someone else on here will have some opinions also but to be honest this question may be getting kinda old to some of the other guys-not tryin to be rude just letting you know
best of luck
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Ed1LE
Sep 30, 2018 09:14 AM
racereese
Oct 3, 2015 03:46 PM
gord327
Oct 3, 2015 01:25 PM
ironbmt
Sep 27, 2015 06:00 AM
