Where to get an LT1 cam and springs?
Also, will this cam swap directly into my 92 RS? I remember someone saying something about the wrong dowel pin?????
Also, I'm on the lookout for a performer TBI intake and headers that will fit my car. Anyone have all these they would sell as a package? : )
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
an lt1 cam with swap directly into a 92 305tbi engine. you can use the stock springs if there good but if there over like 65000 your better off replacing them with GM lt4 springs. a cam swap wont do ya much good if ya dont swap at least intake and do headers and exhast. some heads work would also be helpful but not neccerary .
91 camaro RS
- 305 TBI
Mods: Performer TBI intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter, b+m trans cooler, white guage faces, megashifter..
next month: spohn LCA's and panhard rod, BMR relocation brackets, 323 gear, lt1 cam , 350 heads
91 camaro RS
- 305 TBI
Car: 92RS
Engine: 357
Depending on the year of LT1 cam you might have to grind down the pin so its the same lenght as your stock cam.I had to, but it was easy.I covered up the cam with plastic wrap while I was grinding it down to keep grinding dust off of it.Just make them the same length and have a happy life.
Good luck.
Dave
92RS LO3 700R4
open air element
ultimate TBI mods
LT1 cam
Edelbrock TBI performer manifold
180 thermostat
Hooker headers
3"cat back
Zexel Torsen posi with 3.42 gears
Good luck.
Dave
92RS LO3 700R4
open air element
ultimate TBI mods
LT1 cam
180 thermostat
Hooker headers
3"cat back
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Joker, do you have any times for your car? Seems like you should be in the 14s?
Nice setup!
Chuck Kulchar
1991 RS
Nice setup!
Chuck Kulchar
1991 RS
1988iroc350tpi
Aug 14, 2015 07:52 PM
