Has anyone removed their smog pump?
Old Jul 10, 2001 | 01:31 PM
Taylor92RS's Avatar
How did you do it? Do it help anything? Is it worth doing? Did it set off any trouble codes?
Old Jul 10, 2001 | 01:50 PM
89firebird's Avatar
Car: 89 Firebird Formula T-Top
Engine: SP383 FIRST Fuel Injection
Transmission: T56 Tremec Magnum
Axle/Gears: Moser 12 Bolt, 3.42 Eaton Posi
I just followed the instruction from the tech article. Worked out great, but I think the belt was a little tight IMO. The belt I put on wore out after a few months, so the next time I increased by 1-2CM. The tensioner seems to have the proper tension on it now. Took about 15-20 minutes taking my time.
Old Jul 10, 2001 | 01:58 PM
JPrevost's Avatar
Car: 91 Red Sled
You still have a smog pump! lol
, Jon (350 TBI!)
91 Red My website
Old Jul 10, 2001 | 09:22 PM
ilovemycar's Avatar
Yeah seriously, how do you actually get the pump off?
Old Jul 10, 2001 | 09:34 PM
irocbsa's Avatar
Unbolt the bitch, disconnenct all the hoses coming off of it, and throw the damn thing in the garage. Not hard at all. As mentioned previously though, you will need a shorter belt. Do a search for "smog pump" and you will probably find a part number for the new belt. Or at least a length.
bsa
Old Jul 11, 2001 | 09:43 AM
carter89RS's Avatar
it wont pass emissions if you take to pump off right?
Old Jul 11, 2001 | 09:48 AM
NJ SPEEDER's Avatar
it will pass inspection. the pump is only to help the cat come up to operating temp upon initial start up from cold. it actually turns off after a few mins of running and just drags on the motor slightly.
lata
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Jul 11, 2001 | 10:41 AM
carter89RS's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 89firebird:
I just followed the instruction from the tech article. Worked out great, but I think the belt was a little tight IMO. The belt I put on wore out after a few months, so the next time I increased by 1-2CM. The tensioner seems to have the proper tension on it now. Took about 15-20 minutes taking my time.</font>
what length belt are you running now?
Old Jul 11, 2001 | 11:50 AM
JPrevost's Avatar
Car: 91 Red Sled
People, do a check in the tech articles. They have the belt length listed. I'm not trying to be short with all of you but come on. The first place to go at this site is tech articles THEN board.
To continue on NJSpeeders comment about the pump helping the cat get up to operating temp: That's right on. Basically the pump injects fresh air (with Oxygen) into the exhaust. This increases the temp of the exhaust gas because the oxygen burns and the cat warms up. It works pretty good and it's been proven that the pump on our cars doesn't really suck away power like those 70's smog crap. The only real gain is weight. I probably would have had mine reinstalled but something got into the pump and it wasn't turning. I think the bearing went but I'm not sure. I would only bother taking it off if you are going to do other weight savings like removal of AC and fiberglass hood. To take it off just because is not a good excuse. I'll bet nobody can prove to me that removal actually increased their horsepower. It's basically an alternator fan! It's such a low pressure pump that it draws MAYBE 1hp at like 4500 just because it needs a longer belt!
To each his own, go for it but do other stuff or it won't be worth your time.
, Jon (350 TBI!)
91 Red My website
RazorN8
Jan 7, 2022 11:44 AM
italiano67
Dec 11, 2016 09:21 AM
backtothe80s
Sep 5, 2015 12:39 AM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
