Open element Questions
Old Jul 12, 2001 | 10:49 AM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Ok, I have an open element laying around, but can not get the sensor out of the stupid stock housing. It is in there too good. It feels like something will break if I try to get it off. Are there any tricks to getting it out, or do I have to either break something, or buy a new one? It appears to unscrew from the housing, but won't move at all.
Not enough money, so many things to do.
http://www.geocities.com/tzfbird/tzfbird.html
Old Jul 12, 2001 | 12:33 PM
TZFBird's Avatar
Engine: 327
Sorry, it's the IAT. I tried it again this morning, but it's being a b!$&h. Well, does anyone know how much these things generaly run? It would be nice to still have one in the stock, so when winter rolls around I'm not pumping freezing air into my engine. Power isn't very helpful on ice.
[This message has been edited by snflupigus (edited July 12, 2001).]
Old Jul 12, 2001 | 06:59 PM
One Eyed Jack's Avatar
I just pinched it tight with a pair of pliers and pulled really really hard. It came out.
1992 Pontiac Firebird
- 305ci V8 TBI / Automatic Trans / Loaded
- MODS: Edelbrock 14x3 Open Element Air Cleaner, Dual outlet exhaust
1985 Chevy Z28
- 350ci V8 TPI / Automatic Trans / Paid $200 for it
- In the process of restoration!
Old Jul 12, 2001 | 10:21 PM
TZFBird's Avatar
Engine: 327
I don't know what is up with mine, but it is screwed into a large square copper nut that is tach welded to the filter housing. I have tried uncrewing it, but it is stuck pretty good. I've even tried 2 people unscrewing it, but it won't budge. Just bends a little. I guess I will go with the resistor. How much resistance do I need? I don't want it to think it is too cool.
Old Jul 12, 2001 | 11:13 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
in case anybody else looks here, since ive already told tzf.
3.4k ohm = 68 deg F
theres a good one. but seriously. ive never heard of an iat being mounted like that.
Old Jul 13, 2001 | 06:02 PM
dtpmike's Avatar
just get a hammer and smash the thing back out. Just kidding.
It has a metal jacket on it that you have to squeeze and then pull it out. You may need to work it out and not just pull.
Old Jul 13, 2001 | 09:46 PM
chooch-88formula's Avatar
I was able to get the nut off with a large wrench. try one way then the other... keep going back and forth.... it will come off.
At least if you have the sensor off, you can just hook it up and set it off to the side.
88 Formula WS6 TBI 350
The other hobby
http://home.rochester.rr.com/hoscar/indexn.html
Old Jul 14, 2001 | 12:48 AM
TZFBird's Avatar
Engine: 327
Well, I just used a resistor. I think it was a 3.6k ohm. It seems to work pretty good. But, thanks for the info.
Frozer!!!
Jan 19, 2024 04:55 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
redmaroz
Aug 16, 2015 11:40 PM
wruiz
Aug 13, 2015 09:07 PM
