Fuel pressure gauge on a lo3?????
Car: klowny1969 <-youtube 4 3rd gen vids
Engine: subscribe to klowny1969 on youtube!
Transmission: subscribe to my channel on youtube
just curious to see how to hook up an electric fuel pressure gauge to the lo3 motor
and as far as fuel pressure gauges go , isnt better if they are hooked up past the regulator because the pressure is regulated after it ..not before it..i guess what im saying is ...cant the fuel pressure be different before the regulator as opposed to after the regulator? and knowing that the regulator is in the tbi ...how do you go buy hooking one up ??
on the drivers side of the car, where the fuel lines come up to the motor there is a connector in the lines. screw the pressure sending unit into the larger line(the feed line) at the connector,you may need an adpter or 2 to make it work, i am not sure what the fitting sizes are.
then just run the wires however you want.
lata
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
lata
tim
14.209@95.46mph
Best 60' 1.917
i think i checked that spot ..i dont remember anything there... i could be wrong though..i will check soon again..is it like a schrader valve or something there? and you were talking about a mechanical guage right? thanks.
There is no shraeder valve on TBI'd cars. You would have to (a) cut the fuel lines and splice the sending unit in or (b) find the mythical fittings that will all screw together to do it without cutting/splicing. Someone mentioned that the fittings are actually power steering fittings so maybe look there; or do what I did and splice.
Check my site for pix,
Darth Steve
Steve's Trans Am Temple
Darth Steve
Car: 91 RS
I added a guage last month. Summit Racing part #SUM-G1710. Cut the large hose, slide a hose clamp on each one, push the fitting into the hoses, tighten the clamps and screw in a guage or a sensor fitting of your choice . The threads are 1/8 NPT for this part number. Worth $5.99 to be done in about 5 minutes. Good Luck!
91 RS 350TBI..... Vortec heads..... Holley 670..... Edel. intake .... Lt4 cam 1.6 rollers ..... Edel. TES headers .. 3" exhaust ..... 5spd 3.08
kewl thanks for the info i really appreciate it..i just remembered though that i had to tap into the fuel rail for the nitrous solenoid so i just might get a y block and thread in my friends autometer fuel pressure gauge there and mount it on my hood...thanks for the replies
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
