Holley 4 bbl with stock ecu
Old Jul 17, 2001 | 10:48 AM
skip's Avatar
Has anybody had any experience with "Affordable Fuel INjection", he says he can sell me a ecu and chip (with me to repin my harness) to run a Holley 4bbl tbi. Some of the posts say this won't work. thanks
Old Jul 17, 2001 | 09:58 PM
Tas's Avatar
Tas
if you change to a holley ecu then it should be cool. There are problems running it off the stock ECU at higher RPMs. Do a search for the name "Dan W" this has been talked about before.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Jul 18, 2001 | 09:33 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
ive talked to him a few times. mostly about selling my tbi with his systems. he does some work on the harness and ecm i think, so that you can use the 4bbl without problems. he recomends against holleys ecm because he said it doesnt block outside electronic interferences, ie. he said he knew a guy with a jeep with holley's system, drove under high voltage lines and had to push the jeep half a mile before it would run agian.
get it with a gaurantee.
Old Jul 18, 2001 | 10:53 PM
Dan W's Avatar
<font face="Verdana, Arial" size="2">Originally posted by snflupigus:
</font>
I've run a 4bbl on the stock ECM and later the 747 truck ECM but I'm not the guy that snuf is refering to. Be prepared to do some custom programing as it is absolutly required to make the 4bbl work.
Do a search on this topic as its been discussed before.
1988 T/A,
9" Ford, 3.50 gears, Auburn posi, 700r4 -w- 2100 converter, 360ci, 9.8:1 cr,
AFR 195 Heads, Weiand #7525 intake, Lunati roller 219/227, .479/.480, 112 LSA
GM big block 2bbl TBI on truck 7747 computer
eightsixseven
Dec 16, 2024 01:50 PM
italiano67
Dec 11, 2016 09:21 AM
nuggie
Aug 25, 2015 01:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
