I have a important question
Old Jul 20, 2001 | 05:54 PM
92formula's Avatar
Car: 1992 formula WS6
Engine: none
I do not know if I can post this here but,
If you take the air pump of your car, would you fail a emissions test. I just moved to AZ and my formula does not have a air pump on it at all. Would it fail. I need to now asap?
Old Jul 20, 2001 | 09:24 PM
Andy89RS's Avatar
It will make the cat far less effective anyway... Even if you pass the sniffer portion if you have visual inspections too, you'll fail that part for sure.
Old Jul 20, 2001 | 10:11 PM
92formula's Avatar
Engine: none
Do you think I will pass the sniffer. I found the air pump but no other things that are on the pump. The big question is will it pass the sniffer
Old Jul 21, 2001 | 08:55 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
The only way to know for sure is to have it tested. Best bet is to go to a junkyard to get the parts you need (hoses, diverter valve, etc). You could try decreasing the fuel pressure a bit too. Good luck.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
92GTA
Apr 9, 2016 07:39 AM
E_S
Aug 29, 2015 04:09 AM
redmaroz
Aug 16, 2015 11:40 PM
Ozz1967
Aug 16, 2015 10:23 PM
gta power
Aug 13, 2015 06:15 AM
