TBI EGR help
Old Mar 24, 2007 | 09:40 PM
rsfromhell's Avatar
Car: 89 RS Camaro, 92 RS Camaro
Engine: 2.8 V6, 305 TBI
Transmission: Built 700R4, 700R4
Axle/Gears: 4.10 richmond, Stock
TBI EGR help
Is there any way to remove the EGR system without loosing power?
Old Mar 25, 2007 | 01:46 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: TBI EGR help
The EGR system is the only one the computer checks, so you will set an SES light without it being there and working. You would need a custom chip burned with the code 32 turned off and the EGR functions programmed out to get rid of it.
That said, why do you want to remove it? It does help you get better gas mileage on the highway, and its closed at WOT and does not hurt you.
Old Mar 25, 2007 | 09:55 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: TBI EGR help
Agreed. Other than the engine clutter factor, there really is no point in tossing it....
Old Mar 25, 2007 | 10:58 AM
rsfromhell's Avatar
Re: TBI EGR help
well i just put on a new exhaust and i had the shop cut the cat off and run all new 2.5 pipe back to the flowmaster.
now its running like **** with the air pump running and the pipe for the cat not connected to anything. can i just drill a hole in the exhaust pipe and weld the AIR pipe in it?
Old Mar 25, 2007 | 01:24 PM
Re: TBI EGR help
It's much easiier to pass smog with the air pump off, and catalytic converter on, then it is vice versa. Since you already have the catalytic converter off, just get yourself a smog delete pulley, and call it a day...
Old Mar 25, 2007 | 03:49 PM
rsfromhell's Avatar
Re: TBI EGR help
so what chip do i need, and who by?
Old Mar 27, 2007 | 08:34 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: TBI EGR help
you dont even need a smog delete pulley u can just pull the whole pump off and get a longer belt and reroute your belt. Thiers a picture in the tech department of this website.
sailtexas186548
Feb 17, 2017 03:07 PM
92firebirdguy
Sep 1, 2016 07:53 AM
Glowsock
Sep 11, 2015 11:09 PM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
