which would be faster?
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
an l98 topped with the tbi or still with the tpi? assuming both were tuned "right" in the eprom.
i have a chance to pick up a GTA with the l98, wonering howthings stack up between the two systems
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: which would be faster?
umm id imagine the TPI would be better deffinately..
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
If the TPI is in place and your just going to drive it as is, you might as well just leave the TPI in place for simplicities sake.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Werent the 350 TBI's about 220 HP?
rockit, this topic has been debated since before this website existed. Do a search on "tpi vs tbi" and you'll cry from all the dead horses being beaten.
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
The heads would have limited the output on a TPI long block. GM didn't even get to 300 fwhp until the Ycar LT1 and that was using a slightly higher lift cam and (LT1 / L31 style) heads that were much improved over TPI on both intake and exhaust.
no green
Mar 3, 2016 05:19 PM
