white smoke
Old Jul 28, 2001 | 04:01 PM
bad@ss89camaro's Avatar
Car: 91 Z/28 convertible
white smoke
today i went driving around in my car and a lot of white smoke was coming out of the pipes when i reved it up white smoke came out but then for about 5 to 10 minutes no smoke would come out no matter what i did but when i got home it was smoking and i checked the oil while the engine was running and when i took out the dipstick smoke was coming out of it what causes that and what can be done to fix it
Old Jul 28, 2001 | 06:17 PM
Andy89RS's Avatar
That sounds ominously like a blown head gaket. The white smoke was your coolant being blown out the pipes, and the reason it stopped is the coolant level dropped. Check your coolant, if it's milky or sludgy that's the oil in it. If that's the case, you'll need to replace the head gaskets.
Old Jul 28, 2001 | 09:37 PM
i checked my coolant and it seems to be fine
Old Jul 28, 2001 | 11:52 PM
CrazyHawaiian's Avatar
Car: too many ...
might be carbon buildup ... but sounds off that it would just start happening one day out of nowhere ... check your oil too and make sure there is no water in the oil.
--- Current Daily Driver ---
Maroon 1989 Camaro RS - Crappy 305 TBI / Auto
Hypertech Stage 2 Chip (and 160/ThermoStat)
2.5" Pipes, No Cat, Flowmasters (Dual)
GT Grant Wheel, %5 Tint all around, 50% on windshield
--- Next Project ---
1992 Camaro z28 - 5.7ltr / Auto
6 speed swap, engine internals, turbocharge, SCCA!!!!
Old Jul 30, 2001 | 08:38 PM
just changed the oil and it had no water in it my friends dad said that its probably the valve seals or whatever are worn out and letting oil ontop of the pistons then burning of does that sound right
Old Jul 30, 2001 | 11:19 PM
Andy89RS's Avatar
The only thing that causes white smoke is water/coolant getting burned off. Oil generates a blueish gray smoke and simple bad combustion is black smoke. When you say white smoke, is it really white, like steam, or is it grayer?
Old Jul 31, 2001 | 08:45 AM
MightyMouse's Avatar
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
What does the smoke smell like? If it smells like coolant then plan on replacing a gasket.
Old Jul 31, 2001 | 09:09 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
in my first engine it had bad vavle stem seals witch caused white smoke to blow out the exhaust when you hit the gas beyond a quarter of the way down.. the only other thing is the either headgasket or piston rings.
91 camaro RS
- 305 TBI
Mods: Performer TBI intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter, b+m trans cooler, white guage faces, megashifter..
next month: spohn LCA's and panhard rod, BMR relocation brackets, 323 gear, lt1 cam , 350 heads
Old Jul 31, 2001 | 09:10 AM
bbtaz97's Avatar
Car: 91 RS
the smell with also help you in determining what your burning
Old Jul 31, 2001 | 03:26 PM
its white as clouds on a bright and shiny day and i couldnt really tell you what the smell is its weird smell its not gas or oil i know that
89 camaro
carburated 305
bored .030 over
flat top pistons
bigger valves
heads and block shaved
spoiler
tinted windowshuge white chevy symbol on back
92 stock rims
92 ground effects
www.geocities.com/thirdgenerationcamaro
Old Jul 31, 2001 | 07:09 PM
Andy89RS's Avatar
Does it smell sweet? If so it's coolant. The only way I can think to explain how burning oil smells is you can put a drop (just one little drop) of oil on hot exhaust manifolds, and take a whiff. It only takes very small amounts of oil to smoke up a whole lot.
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
