cam replacement
Old Aug 13, 2001 | 10:52 AM
91rscruiser's Avatar
cam replacement
ok when i go to replace the cam in my LO3 do i NEED to get a hydraulic roller cam and lifters or can i get the cheaper standard hydraulic setup.whenever ive seen the hydraulic roller cams it always says its for 87-up motors,but i would much rather go for the cheaper standard hydraulic cams if i can get away with it.snflupigus told me to go with a comp cams xtreme energy cam 262 grind,and ive only seen that in standard hydraulic form,so im assuming that means the hydraulic will work.thanks for the help guys.
-1991 camaro rs,dark red metallic,t-tops,stock 15inch rims
-stock L03 305,TH700R4,2.73's,only mod for now is a Flowmaster 80 series replacement muffler.
-best 1/4 mile times:16.2@84/2.37 60ft
Old Aug 13, 2001 | 11:33 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
I wouldn't recommend switching to a flat tappet cam. They have a lot more friction which cost HP than same specs on roller. Buy a used LT1 cam if you want more power from stock motor or go with a ZZ4 roller cam if you are going to mess with more parts of motor like heads and intake. These cams don't wear like flat tappet cams and are ok to buy used. Same with the lifters. Just reuse your roller lifters with your new roller cam. You can find either on this board under the classified section or on ebay. You will be happier and your computer will probably thank you too since most roller cams are computer friendly.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
Old Aug 13, 2001 | 12:31 PM
sbrice18fan's Avatar
Car: 1990 Chevrolet Camaro RS
I agree, I would stay with the roller cam, you may pay more, but your engine and computer will be much happier. You do want to stay around a 112 lobe center. a 108 or 110 will give your computer trouble. Comp Cams makes some good replacement roller cams. Part # 8-500-8 works with basically stock TBI and has 206-212 duration @.050 and 480-488 lift on a 112 lobe center or you can find a good used roller cam. See what other people say, this is a great forum for advice.
1990 RS Camaro 305 TBI 700R4 Tranny
3" cat back system with flowmaster muffler
Edelbrock strut brace tower and rear panhard bar
Spohn subframe conectors and lower control arms
all polyurithene bushing under the car
March underdrive pully system
K&N air filter
Hypertech chip
Aluminum driveshaft
3.42 posi rearend
Killer sound system
Many new mods to come
Old Aug 13, 2001 | 08:32 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Stick with a roller. By the time you add up the cost of having to replace the timing chain, sprockets, & pushrods to use a flat tappet, it's not gonna be much cheaper that going with a roller replacement.
Hell, if you can find a used LT1 cam, do that. You can reuse your stock lifters & buy a new GM replacement chain & sprockets for $40. PN #12371043. Just make sure the pushrods aren't bent and that the roller lifters aren't sticking and you'll be fine. Oh, and check the springs to. If your pushin' 100k miles, then they are surely worn
Good luck
AJ
Old Oct 4, 2010 | 08:10 PM
rich6675's Avatar
Re: cam replacement
Is it nesessary to get a new chip when installing an Lt1 cam in a stock Lo3?
Old Oct 4, 2010 | 09:49 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Re: cam replacement
Oh yeah, you'll be lucky to even start the car with an LT1 cam and the stock tune. EBL Flash is the way to go.
www.dynamicefi.com
Fronzizzle
Mar 18, 2019 08:29 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
Fronzizzle
Aug 9, 2015 01:15 PM
