Height question
Old Apr 3, 2007 | 08:18 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Height question
Was thinking of using a Edelbrock RPM Intake, and a adapter plate for my TBI...I am using the stock aircleaner (Modded out), and want to keep using it.....Am I going to have hood clearance problems???????? If so, what do you guy suggest???? I want to keep the stock breather for the time being....If there is a better setup, please let me knoe what you think....Would like to pick up some power, and throtle response......Thanks alot, Tom
Old Apr 4, 2007 | 07:07 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Re: Height question
The performer RPM is THE best dual plane intake out there, unfortunatly it's a bear to get under the hood of a camaro. Your best bet is to get some silly putty and see how much room you have obove your air cleaner. You are going to need well over 1.5" of clearance to get the RPM to fit. My brother is running a GMPP dual plane with a drop base air cleaner and a 2" filter and it just clears the hood, the bad thing is this intake is a good 1/2" shorter than a RPM.
Old Apr 5, 2007 | 07:19 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Re: Height question
Yeah i will check, I really want to go the RPM route if I can.........Do they work well with the TBI???? On my last car I had the plain performer, it was carbed tho, and worked very well..Thanks, Tom
Old Apr 5, 2007 | 07:16 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Height question
hood space is very very limited i doubt that it would work. maybe a 2 inch cowl hood can be in ur future
Old Apr 5, 2007 | 11:01 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Re: Height question
What is good, that will fit with the adapter plate????????? What intake are some of you guys with stock hoods running????? I know this is a beat subject, but I really hope to find a good compromise between height, and performance....I kinda think I want a single plane....Is there any difference in the dual plane versus the single plane with a TBI....I know that on a carbed motor a single plane will kill some low end power, but be better on the high revs....A dual plane is better for low RPM's and not as good on the high revs....BUT does that apply with fuel injection.....I have read on some of the stickies that it does not seem to matter......Please help in this manner...There is a cowl in my future, BUT that is way off...Thanks, Tom
Old Apr 8, 2007 | 09:37 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Re: Height question
Still searching..........
customblackbird
Aug 15, 2021 10:16 PM
92GTA
Apr 9, 2016 07:39 AM
Horridbulldog
Wheels and Tires
Feb 13, 2016 07:22 AM
gixxer92
Sep 1, 2015 04:32 PM
redmaroz
Aug 16, 2015 11:40 PM
