what should I expect
Old Aug 25, 2001 | 05:15 PM
jmp1999's Avatar
Just out of curiosity, what do you think ill run in the 1/4 mile. Im going witin a month. Would like to wait till custom chip is in. (Have to order it yet) 1988 camaro
350
305 TBI with 65 lb hr injectors
1 5/8" heddman headers
edlebrock catback exhaust
three angle job on valves on 305 heads
stock type pistons( dished)
4.10 rear gears
.430 I .444 E cam (or something mild like that)
100 hp shot of nitrous (will change to 120 if needed to break an even time)
posi Boxed lower control arms
B&M meagashifter
and the one mod that needs to be done before I go is the chip.
Old Aug 25, 2001 | 11:26 PM
steve8586iroc's Avatar
I hope you have a tank full of 110oct race gas. Your compression with the 305 heads will be up to the 10.0/1 mark. This isn't to bad with aluminum heads but with iron heads it will be tricky. Be careful with the nox, you could hurt the engine real easy if it's not setup correctly.
ZZ3Astro
Aug 13, 2019 12:57 AM
86z89iroc
Oct 5, 2015 01:04 PM
hartsmike
Oct 2, 2015 07:11 AM
80smetalfan
Sep 22, 2015 02:55 PM
BWilcox
Sep 20, 2015 12:19 PM
