hey JPREVOST
Old Aug 29, 2001 | 05:20 PM
jmp1999's Avatar
hey JPREVOST
This is in pesonse to your message that you put on the other board. I say try it, bu tmake sure that you buy the pressure saftey switch from NOS. for like 30 bucks its a great investment for peice of mind. I have one on mine with the 100 hp shot and would not be scared to run 125. (might do it).
If the system cycles and wot like its turning on and off, or doesent turn on at all. THen take the time to drop the tank. Sounded like a huge pain in the but to me. I am howver making less hp than you with motor, and have heard the the stock pump will only support like just over 400. So ur pry pushin it.
jus my opinion though.
Joel p
Old Aug 31, 2001 | 01:29 AM
JPrevost's Avatar
Car: 91 Red Sled
I have a really good feeling that my fuel pump is on it's way out. This weekend I'm going to do some plug cuts to check to make sure the car is starving up top. If it is then I know it's got to be my fuel pump and I'll attach a fuel pressure guage so I can see it from within the car. If that conferms it then the pump will be replaced with a walbro either 190 of 255 low pressure pump.
Thanks for posting on the TBI board.
, Jon (350 TBI!)
91 Red My website
Old Aug 31, 2001 | 09:27 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
I went with the 255lph Walbro pump because I only want to do that job once. My car is still rather stock but I am getting it prepared for the vortec swap.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
Loudnproud86
Jul 14, 2016 12:59 AM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
Zane Story
Oct 8, 2015 12:40 PM
chuck13
Interior Parts Wanted
Sep 22, 2015 11:19 AM
Keiffer76
Sep 9, 2015 08:52 PM
