Confused idle on start-up...
Old Aug 30, 2001 | 04:14 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I realize that I am far from an F-body, but my engine controls are almost exactly the same, minus and IAT.
When I start my van, the idle goes up and the quickly drops and then shoots back up again and....about 700-1200 rpm range.
If you tap the gas, it'll stop for the most part. The first time you come to a stop the idle is fine. I have ALL NEW sensors, so now it's down to what is just not operating properly.
'92 Astro 350 TBI Edelbrock intake, MSD 6AL, 3.42's, 2.5" exhaust, Flowmaster 40 2 chamber, B&M 2nd stage shift kit, 255 60 R15 tires on AR-727's
Old Aug 30, 2001 | 04:24 PM
NJ SPEEDER's Avatar
first i hafta say that your ride sounds sick, and i think that is beautiful
have you checked/replaced you IAC? if it is messed up and not responding properly it will cause the idle to dart around until the motor is warn enough to just close it all the way.
also check the adjustment on the throttle position sensor. it should read .5 volts at idle. if it is not or if it does not come back to the same stop once reved that could cause it to think it is being reved a bit when it really isn't.
hope this helps.
lata
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Aug 31, 2001 | 12:28 AM
Car: Bee-Bowdy
Axle/Gears: fo-tins
Thanks for the info. I got it nailed down tonight before I checked the post.
I had to use a '91 fullsize pickup ECM (1227747) to run the 350 because in '92 they changed some of the ECM and wiring harness pinouts on the Astro. Turns out they had switched the two ground wires at the IAC and not the ECM.
I switched them and bingo. I'm out to eat some Mustangs...
Old Aug 31, 2001 | 08:57 PM
Neo's Avatar
Neo
I knowq it off topic but do you have pics of your van? I have to see this. Do you have a full interior?
Old Sep 3, 2001 | 11:56 AM
Keith5's Avatar
Car: C1500
Why wouldn't he have a full interior?
Old Sep 4, 2001 | 09:31 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
all my pictures are here. But beware, I also have a Fox-body Mustang!
And yes, my van is WAY faster than the Fixed-On-Race-Day mobile.
http://communities.msn.com/V8AstroCaptain/shoebox.msnw
don't forget to view page 2 of Shoebox, that's where the lastest pics are.
Jorlain
Oct 8, 2015 01:57 AM
IROCtometal
Sep 20, 2015 11:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
greenyone
Sep 8, 2015 08:41 PM
