oh yea!!!...?
Old Sep 5, 2001 | 07:09 PM
firbird's Avatar
oh yea!!!...?
i finally got my engine to run decent and idle took only 2 months but any ways i go down the street and there there was a big clack and my engine dies and i am still going and it starts back up and it did that several times before i could get back to my house and was wondering what that is?? is it a spark jumping? something jumping around in my engine? i dont really know it is dark now so i am going to wait tomarrow but i would like to know what would cause that i just think it is a spark jumping because it is able to save its self sometimes when it is higher than idle speed so nothing is really locking up.
i would also like to thank every one on this board for there help and special thanks to njspeeder tim, deadbird ken, brian felts, and jprovest jon, for directing me the right way thought this project of mine.
thanks,
danny
Old Sep 5, 2001 | 09:10 PM
firbird's Avatar
oh yea my brakes dont work too good and i think i am not getting enough vacume, when i push the breaks lightly it stops normally and when i push hard on it it is like a rock and it doesnt stop too good. i dont think it is becasue i need to bleed the breaks because when you need to bleed it, it is really soft. i hooked it up to the screw in vacume line that is behind the tbi unit but that was not good enough so tried one of the open vacume lines infront of the tbi unit that i had blocked before because i was not using them but i dont think it is still good enough, where should i hook it up now? should i combine the 2 open ones in the front.
Old Sep 6, 2001 | 02:44 PM
firbird's Avatar
i drove it again today and and noticed when i try to go over something like 2500 rpms it clicks and dies and i cant find any thing wronge with the ignition by looking at it. and when i get it close to 2500 rmp it does not want to go any higher at all and when i rev it to 2500 when it is parked it does not want to at all and decreses the rpm very slowly when let off of the gas.
anybody???
[This message has been edited by firbird (edited September 06, 2001).]
Old Sep 6, 2001 | 05:26 PM
NotDadsW41's Avatar
Check the power wire and/or ground wire to your fuel pump relay. Something could be loose there and when you rev the car is pulls or moves off contact and the stalling occurs.
Old Sep 6, 2001 | 05:44 PM
firbird's Avatar
i dont think it is that because i can go over bumps and stuff and it does not do that i think it is the Ignition Modual like someone advised me. this may sound stupid but where is it? and can it be swaped with a 86 T/A Ignition Modual becasue i am already useing the dist from it.
Old Sep 6, 2001 | 08:29 PM
firbird's Avatar
never mind i know where it is now and i will be doing the swap tomarrow just hope that is it. any thing else??
Pac J
May 17, 2020 10:44 AM
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
383backinblack
Oct 14, 2015 08:50 PM
gta892000
Sep 16, 2015 12:40 AM
