Edelbrock TIB Intake
Old Apr 9, 2007 | 07:37 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Who all is running the Edelbrock TBI intake on a 305 LO3????
How much of a difference did it make????? And MOST IMPORTANT,
Would you buy it again????? I know this is a beat subject, but am going to try to get an intake, and would like all the input I can get......Thanks, Tom
Old Apr 9, 2007 | 09:09 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Re: Edelbrock TIB Intake
I have it and I like it.Although i had my bores opened up to 2 inch and I port matched the runners.All in all I am pleased.the car definately pulled alittle better with it.
Old Apr 9, 2007 | 09:13 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Robertfrank, thanks for the heads up..........I just cant decide what intake to use...Was thinking about a single plane with the TBI adapter on it, but am afraid it wont clear the stock hood......TOO MANY CHOICES...........
Old Apr 9, 2007 | 11:10 PM
1992camarors's Avatar
Car: 1992 Camaro RS (Z28 Clone) Z03
Engine: 305 TBI
Axle/Gears: Eaton POSI/ 3.73
I am also running the Edelbrock Performer TBI intake manifold. As robertfrank said it made my car pull much harder across the whole powerband. I really can't compare how it changed the performance by itself because I rebuilt the engine and added many other performance parts at the same time.
Old Apr 10, 2007 | 09:53 AM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
1992camarors,
Are you riding a 3.73 rear on a daily driver?
Old Apr 10, 2007 | 02:34 PM
Engine: 305 TBI
Yeah I am running 3.73s in it. It really does pretty well on gas mileage though.
Old Apr 10, 2007 | 10:46 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
I was going to start a new thread, but this one
is already going in several directions I'm interested
in, and I know galileo is considering the 3.73 gear
change also.
First the 3704 question.
I'm starting with a 2" throttle body, that will be sitting
atop a juice injector plate, with 2" bores, so the main
consideration is overall flow, rather than throttle blade
clearance. There's 2 options:
1) Have the ports bored by the local machinist, expected
cost $50 - 75.
2) Taper the bores, which I can do myself.
Any thoughts on the performance difference vs. cost-effectiveness?
3.xx gears:
If the 700R4 is the o-d automatic, does anybody have a
correctly calibrated speedo, to indicate 60mph vs. rpm,
for both the 3.23 & 3.73 ratios?
thanks,
kk
Old Apr 11, 2007 | 01:13 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Hey long distance, Im not worried about the 2 inch bore right now (will be some day) I just want to know if this is a good intake............
I must have the 3.73 gears, and my 3.23 gears are yours...........
I know the OD will handle them ok.......
I dont know if I should get the TBI intake, or a single plane intake......If it was a carb, I would know what to do, but this is my first fuel injection ride...Come on guys chime in on this for me.....................I know there are a lot of threads on this, but help me out on this..Wish I had a 2 inch cowl hood...Thanks, Tom
Old Apr 11, 2007 | 08:19 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I had one on my car before the TPI swap. Mine is an early version that has the removeable "torque tubes" as edelbrock calls them which let you change where the power band is. Tubes in keeps it down low while no tubes moves it up into the midrange. I ran without the tubes when I had my 3.73 rear which helped it some.
Old Apr 11, 2007 | 09:46 AM
Cadillac's Avatar
You know, I simply don't believe you. If you think 14 MPG is good, then that is where the discrepancy would be.
Old Apr 11, 2007 | 09:52 AM
Tom,
Toss that old nifty-fifties corroded alum 4-brl intake
into the lizard cage for a pedestal, and snag a 3704.
Everybody says its an improvement, & it's bolt-on
compatible, including the off-set center bolts.
Cost-benefit is the only real question. New at $340+
is debatable, e-bay for $150 becomes much easier.
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Im not to concerned with milage right now...I dont drive far to work anyway, and hardly ever drive my car for anything serious....Which way to go, Edelbrock TBI Intake, or a single plane Intake??? Any of you guys know of dyno studys on this????? what about drivability, ie: Throtle response???
Old Apr 11, 2007 | 04:01 PM
Engine: 305 TBI
Well if 21mpg on the highway sounds bad then I think you must be use to driving a iron duke with 2.73s. But seriously I get around 15-16mpg when I am easy on it in town. About the same as my dads 2001 Silverado 5.3 4x4 with 3.73s.
Old Apr 11, 2007 | 04:40 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
i get about 21-22 mpg out of my 350 tbi on the highway with 3.08 gears, around town...im a lead foot.
and i do like my eddy tbi manifold.
Old Apr 11, 2007 | 06:14 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
249 dollars at summit, and jegs...Summit is 5 cents cheaper..........I just cant decide if I want the single plane, or the TBI intake......I've heard real good things about single planes with TBI....It makes sense to me that with the fuel being pushed (Injected) into the intake you would not lose low end response, but still have great hi RPM....I know im making a big deal out of this, but money is so tight, and I want the most bang for my buck.......Im going to get one or the other this week...Whatever I get I will want to use it on the 350 im getting this next month....Wont have it ready to use for awhile, but I will be working on it....Tom
BTW, Long distance, do the 350's have that weird off set bolt, or is that just the 305 heads??????
Old Apr 11, 2007 | 07:14 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
on the manifold? if its the 87-95 it sure does.
Old Apr 11, 2007 | 08:36 PM
pete92rs's Avatar
I have the edelbrock TBI intake, here are my thoughts: Pros: easy to install, everything converts from the old intake to the new one, clears stock hood, no adjustments needed to the throttle cable, documented hp increase I gained 9hp and 11lbs tq I also did the ultimate TBI mods, K&N Open Element, along with the Intake so how much power I gained from just the intake alone I don't know. Cons: I don't know how it will flow on a 350, need to bore it out for a 2in TBI which I am sure you will be using on a 350. I paid 214 for mine so that, plus a weekends work made it worth it for me.
Old Apr 11, 2007 | 08:58 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
So you went from all stock to a TBI intake, mods on your TBI, and did the open element breather, and only got 9 ponies???? How about drivability, did it improve???
Ive already got cool air, ram air setup with K&N filter, have done some of the TBI mods with Injector Pod Spacer, so I probably would'nt get alot out of the intake then.....Kinda thinking a Single Plane might give better results...I know it is alot more work tho......Thank you very much for your reply
Old Apr 11, 2007 | 09:17 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I couldn't agree more with pete92RS. The reason why you can count the power increase with one hand is because the stock intake is more than capable of feeding the stock cam. The intake is not the bottleneck. Therefore, any intake swap with retention of the stock cam, will yield negligible results. The stock heads and intake are enough to feed a stock cammed LO3. The exhaust is the first bottleneck with the cam being the second. Once you have headers and a full exhaust the best power per dollar spent comes in the form of a cam swap and PROM tuning. All other mods are in vain (although they will support power down the road).
The TBI intake is a great stock replacement, has the ability to be bored, and should support a solid amount of power on a hot 305 or mild 350. On a stock LO3 though you shouldn't focus on power gains but instead the learning opportunity to properly install an intake manifold.
Old Apr 12, 2007 | 07:04 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Well thank you, I've changed probably around 25 intakes,or so..(Raced Dodges for years).The learning I can do without...LOL.....Just never had a computer controlled vehicle before.....Im just curious the differences of carbed (Which I know well) and Fuel Injection.....I see what you mean about the intake not being the bottle neck.........Well, maybe, I will go ahead, and cam cam it while im at it.....I thank all you guys gor letting me pick your brains on this subject, Tom
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Rally Smith
Sep 14, 2015 06:59 PM
toronto formula
Sep 10, 2015 07:31 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
