305 Engine upgrade..help please...deciding
Old Sep 10, 2001 | 09:29 PM
91camaro305RS's Avatar
Ok here goes...I'm planning on putting a intake,cam,and headers on my 91 camaro Rs 305.....i want to keep my tbi setup..and obviosly upgrade my prom..chit whatever.......so far i like the ceramic -metallic coated shorty hearders from pace setters.....intake and cam still ??? i want the best setup......without much guess work....i plan on putting a new water pump and a gear timing system....along with some crome stuff....also on valve covers.....if i get a came will i need to get tall covers or not... i want a good cam most hp gain but without throwin my computer off....maybe a lil rough idle if possible....butit that cant be done with the computer...the best lift possible....i'll also removed the smog system and plan on using a open element breather.....any suggestions would be great...possible prices to....i have a good bases on installin this stuff..but i'm gonn ahve someone help me in my garage i think
thanks allot!!
nathan
Old Sep 11, 2001 | 10:30 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Edelbrock TBI intake. A used LT1 cam works very well in the TBI cars. If your going to change the heads too you can run the LT4 hot cam otherwise I recommend the LT1 cam. Get the LT1 valve springs too. You can find the cam on ebay or on the other boards classifieds for well under $100.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
Old Sep 11, 2001 | 10:46 AM
lars92RS's Avatar
Car: '92 RS
Engine: In pieces
Transmission: Built 4L60
First off shorty headers on a 305 IMHO probably isn't the best setup. The shorter the tubes the higher the RPM is when you reach your peak. And the 305 isn't known to be a spinner. Also the Edelbrock TBI intake is not exactly a prime candidate for a high revving engine. the LT-1 cam however is a good choice. You will need Chip work as TBI motors don't accept cam swaps very well. You will get your rough idle but it will be rich as $hit. I would reccomend performer or performer RPM if you are he11 bent on your shorty headers and maybe a little longer cam than the LT-1 would help too. But with all that you WILL! need chip work to get the full potetial of your setup
-Lars
Old Sep 11, 2001 | 09:50 PM
what kinda lt1 cam woudld i need? the grind?
i plan on putting a double roller cam chain also....and maybe a new water pump....also wghat kinda cam setup and what indo would i need when i go to the auto store.?
thanks
nathan
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
