Answers & Opinions Needed
Old Sep 10, 2001 | 11:54 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I was driving home yesterday when I noticed my engine was running hotter than normal, but not overheating.
After a thorough check I found out the car was almost out of oil and there is a noticeable leak under the engine. I'm almost certain its the rear main seal, since I've known about this particular leak for several months....it was never this bad until now.
Now for the questions:
1-What is an approximate cost for fixing this?
2-Does it require removing the engine?
If it does, I will probably get an LT1 cam and timing chain installed as well.
3-Will an LT1 cam work well with the LO3 chip?
4-Has anybody swapped to this cam and passed emissions?
Any informative opinions are welcome!
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old Sep 10, 2001 | 03:07 PM
NJ SPEEDER's Avatar
according to the math the LT1 cam will have only about 1/4 inch less vacuum than the stock peanut. this should not effect the operation of the computer at all. you will need to run a little more timing advance and fuel pressure to compensate for the cam, but the computer operation will be uneffected. you will need a custom chip to get everything out of the cam though.
since it won't bnother the computer and it will have plenty of vacuum to operate your EGR i can't see why it wouldn't pass emissions.
i will be able to tell you soon enough, more on that in another post
later
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Sep 11, 2001 | 06:10 AM
Pukka's Avatar
Anybody else???
Old Sep 11, 2001 | 10:34 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
I agree with NJ speeder.
Old Sep 11, 2001 | 10:54 AM
lars92RS's Avatar
Car: '92 RS
Engine: In pieces
Transmission: Built 4L60
I don't agree completey with Speeder although he is somewhat corect. You will most likely need a new chip. However I believe that the ANLU bin will help you out tremendously. You will see a gain in performance and emissions shouldn't be a problem if you can get the right chip work done.
No you don't have to removehe engine to put in a new cam
-Lars
'92 RS 305 TBI
K&N Open Element
Ultimate TBI mod's
Cam[.442"/.465"] x 218*/224* @ .050", 10:1 Hypereutectic Pistons
Performer Manifold
Shift Kit, Corvette servo,
and 2800 Stall Trans Specialties Converter,
Gutted Cat, IAT Resistor
MSD Blaster Coil, Accel Cap and Rotor,
Hooker 3" cat-back
Old Sep 12, 2001 | 07:29 PM
Pukka's Avatar
My mechanic told me it would cost about $350 to replace the rear main seal. He said he wouldn't have to remove the engine, just the tranny. Don't have the time or tools to attempt it myself.
Thanks for the info.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
