Resistor, for a little more go go juice
I have a 89 RS 305TBI here are the few mods:
better flowing induction via ultimate TBI mods, Hooker catback w/ hi flow cat,timing advance to 4 deg.. other than that its stock,Do I need a little more gas. If so what resister do I use. Oh and the resister goes in the sensor thats inside the air filter area, right?
89 RS 305 TBI/Hooker catback-hi flow cat/3.42 gears/ To import racers;there's no replacement for displacement!
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
read the open element tech article. in the sig
Dale Earnhardt, #3 has crossed the finish line with a victory.
IM: snflupigus | ICQ: 96787192
Snflupigus.com
Open Element Tech Article
ENGINE SPECS:
Stock Rating: 170bhp & 255ft-lbs
305 TBI,Open Element,K&N 14x3,Hypertech Stage I,454 GM TBI
Now Rating: A Little More
STEREO SPECS:
JVC Kalmeleon kdlx3,Infinity Kappa 2way 6x9's,PPI 4x6 Coaxials,PPI PC2400 AMP @ 2ohm
DEI Studio 12" 4ohm DVC,Custom Box:Exactly 1 Cubic Foot
Snflupigus.com
ENGINE SPECS:
STEREO SPECS:
If you're running lean, you have other problems that should be addressed before you go cutting sensors out of the picture. And there are correct ways to add fuel...
I wouldn't call that "mod" "rice", but it's pretty sloppy. In the same neighborhood as duct taping a plastic bag to your car instead of replacing a broken window.
resistor is starting point, seems simple to newbies, might see something gained, mostly imaginary, but it can change the fuel settings.
using your correct iat is best for drivabiltiy. quick strip, put one in, take it out before you go home.
btw, i am against using a resistor to tune your car all the time. it is sloppy, but can lead to somebody trying things learning and realizing. "hey, i guess i can sorta work on my car without breakin it". really though, reading first is best, dont use it as a crutch.
[This message has been edited by snflupigus (edited September 12, 2001).]
Elephantismo
Feb 13, 2019 12:51 AM
