is it worth it?
Car: 2000CamaroSS,69 Camaro SS,91 Camaro
Engine: 383
Transmission: TH 400
Axle/Gears: Stock
Re: is it worth it?
What are you palnning on doing? anything will help out but it depends on how far you want to go. Otherwise, I myself would just build a larger cubed motor.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: is it worth it?
First.....welcome top the board. You will lots of good people willing to help.
You need to be more specific and realistic on how much power you want. If you want say 300+ hp, best to go the TPI route. If you are looking for an extra 30 or 40 hp over the stock 170hp there are mods that can be done.
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Re: is it worth it?
go home TPI boy, TBI is just as capable of making power as TBI. It's been discussed to death on this board, you'll gain nothing but 20 ft/lb over 1000 rpm in the bottom range and lighten you wallet enough that you could have made a ton of power with TBI.
To the original poster.....please please read the stickies. All the information you need is already posted in those threads at the top of the forum.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: is it worth it?
skinny z
Oct 5, 2015 06:23 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
Please see TBI buildup on the home page. How deep do you want to get into it? fail to plan, plan to fail.
