Timing Advance
Car: 1989 Camaro RS (w/Z28 tags)
Engine: 305CID TBI
Transmission: Manual - T-5
Axle/Gears: Stock
Timing Advance
How far forward is the computer supposed to advance the timing? I was checking my timing today with the EST connector disconnected. It is exactly 0*. However, I hooked the EST connector back up and decided to check the timing again. This time the timing was almost off the gauge on the timing cover. I gave it some throttle and was checking the timing simultaneously and noticed that the timing mark wasn't even registering. Is this normal for a stock chip?
Re: Timing Advance
Sounds about right to me. The ECM throws in a ton of timing, even at idle, over the base setting. That's why it's so important to unplug the timing wire when setting base timing- you can imagine how far off it would be if you didn't!
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
Re: Timing Advance
Timing is typically 20+ degrees total, even at idle.
Only at WOT less than 2000 or so rpms should timing ever be less than "past the marker".
Engine: 305CID TBI
Axle/Gears: Stock
Re: Timing Advance
All right, thanks guys. I appreciate the insight. I have been trying to get this car to pass smog for a while now. Finally got a new cat for it to be welded in, and just recently put my stock chip in. I am just trying to make sure everything is running right before dumping some more money on a smog test.
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
