1000CFM TBI unit
Old Apr 13, 2007 | 12:06 AM
Rocket-Doc's Avatar
Car: 1990 RS/SS modified
Engine: 355ci, 113 heads, LT4 hotcam
Axle/Gears: 3.73 Eaton posi
1000CFM TBI unit
Has anyone ever considered just gutting the stock TBI and sleeving the center to be a single blade oval? Does the injector pod really need 3 screws to keep it secure. Removing the center would have to be good for atleast 300CFM depending on the throttle bore size.
Figure CNC the center right out and use .0625 aluminum for the sleeve. Just a thought.
I have a spare TBI unit if anyone cared to try......
Comments?
Old Apr 13, 2007 | 01:44 AM
RITTER's Avatar
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Re: 1000CFM TBI unit
hmmmm......it seems like it would work! I mean the TPI throttle bodies are oval so why couldn't the TBI one's be oval!?!
Although you would also have to cut out the intake as well!
You would probably also need one single large injector unless of course some how you used the two existing injector thingy's!
If I had the machinery then I would do it!
Old Apr 13, 2007 | 08:03 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Street Lethal did something similar to this. See his 'Connan the destroyer' thread.
His is probably as close as you can get without plowing over all the passages in the TBI.
Old Apr 13, 2007 | 08:42 AM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Nope, sure doesn't:
http://www.imagestation.com/album/?id=2134511718
Old Apr 13, 2007 | 09:58 AM
Rocket-Doc's Avatar
Ritter,
No way to mount only 1 injector, plus it would be next to impossible to get 1 injector to flow as high was we needed.
va454ss,
You mean it doesn't need 3 screws right? Not the 300 CFM? Who did your unit?
dimented24x7,
What would it matter if we removed the passages? Its just the vacumm, as long as it was notched out in the sleeve, it would still do its job
Old Apr 13, 2007 | 10:26 AM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
va454ss,
Correct. In the pic you can see the center support for the pod is gone.
A guy over at www.454ss.com modifies the TB's. Bores are cut out and sleeved to 2.2"; also uses a thin throttle shaft.
Old Apr 13, 2007 | 10:38 AM
Rocket-Doc's Avatar
Can you cet a better pic? Also do you have the guys email address?
Old Apr 13, 2007 | 11:38 AM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
What do you want to see, specifically?
PM sent.
Old Apr 13, 2007 | 12:00 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Could you get us in touch with this fella? My blower needs alot more air than the stock BBC TBI can deliver.
Old Apr 13, 2007 | 01:04 PM
Rocket-Doc's Avatar
Mic,
I'm already on it..
Old Apr 13, 2007 | 01:35 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Ritter,
dimented24x7,
Not really, so long as you dont cut excessivly into the vacuum nipples or go through the casting. Youd also have to stay within 1/8" of the perimeter of the TBI gasket. In addition, you also have to be careful with the throttle shaft. With a large monoblade, it will be subjected to alot of force from the pressure differential (up to around 12 PSI or so on decel)
Just out of curiosity, what kind of pressure drop are you seeing across the TB?
Last edited by dimented24x7; Apr 13, 2007 at 01:44 PM. Reason: Automerged Doublepost
Old Apr 13, 2007 | 04:01 PM
Rocket-Doc's Avatar
I believe V8Astro Captain was running a Bogajet 750 CFM and was getting 6PSI, now with the TBI 50mm bore he is only getting 3PSI.
92firebirdguy
Sep 1, 2016 07:53 AM
Glowsock
Sep 11, 2015 11:09 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
Glowsock
Sep 5, 2015 07:48 PM
