12-13 hwy mpg and overheating
Old Oct 2, 2001 | 11:00 AM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
I think I figured out that my water pump is shot (which sux cause it's brand new). The upper hose should feel stiff at idle, right? I can squeeze the hose almost all the way off at idle. Also, I'm getting really crappy milage on the road, and I bog down a lot. Is this a vacuum leak? I have an in-line pump designed for TPI, but also have the stock regulator. DO you think that my regulator is shot due to the high pressure (I haven't installed a pressure guage so can't tell what pressure I'm running)? I checked a plug and I didn't see any signs of gas fouling, but then again I checked only one plug. Any ideas? Also, what would be a good in-line fuel pump to run. It's obvious that this one is too much for me. What about the Summit fuel pump (18 PSI)?
91RS convertible 355 TBI 65# inj. custom compcam grind .480/.480, Edelbrock TBI manifold, open element, hedman hedders, Y-pipe, cheap cherry bomb muffler, Hypertech cop car thermomaster, Accel coil, wires. 2.02/1.6 cast iron heads. Engine specially made by Pflugerville machine shop. Forged bottom end, balanced. Coming soon: Vacuum controlled FPR, better exhaust, Torque converter, DIY PROM, bigger TB.
Old Oct 2, 2001 | 01:51 PM
cobrakiller1989's Avatar
the upper radiator hose shouldnt be too stiff if your thermostat is open. When is the car overheating highway/city? I had a problem with my car getting hot on the highway and it turns out that my lower airdam broke off and my radiator wasnt getting any cool air. As far as gas mileage, have you changed ur fuel filter recently? ignition stuff? just all suggestions
*1989 RS
*Red, Daytona Turbo fiberglass hood, chrome 16x8 IROC wheels
*355 CID
*TPI ported plenum, SLP siamesed runners, Edelbrock high flow intake
*Edelbrock TES Headers (getting SLP 1 3/4)
*Richmond 3.73, Auburn Posi
*Modded 700-R4, 2800 stall converter
Old Oct 2, 2001 | 05:36 PM
JRoy91RS's Avatar
Engine: 355
The car runs nice and cool on the highway, but as soon as I pull to a stop, I can watch the temp guage climb and climb without end. It sucks. Not only is the upper hose not stiff at idle, I can squeeze it to where it touches itself on the inside. Not good. Bad water pump.
Old Oct 2, 2001 | 10:09 PM
ChevelleCLM's Avatar
Is your fan working?
69 Chevelle 2dr hardtop blue, bench seats, 12 bolt w/3.73's muncie 4 speed. TBI w/custom harness and prom best 14.5@90
Old Oct 3, 2001 | 07:39 AM
JRoy91RS's Avatar
Engine: 355
Yep, fan works. Of course, it's not coming on until 240*. I'm going to put in this water pump to see if that helps. What do you think about my other problem?
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
James Sutton
Sep 23, 2015 02:18 PM
ssgt usaf
Sep 21, 2015 12:45 PM
