Snuf: TBI unit still in limbo??
Old Oct 1, 2001 | 03:48 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Just wanted to get an update if there was one. Also wanted to ask a couple of more questions. I realize, it might not be a good idea to post on here because of copyright issues so you can always IM me or email me. I was wondering what the exact bore size will be and what it will flow. I was also curious about the actual structure. Is it similar to our normal throttle bodies? I never did like the idea of the pod being in the way of air flow. If you can't answer some of this I understand. No prob. Good luck by the way. If you ever get some produced I need two of them, polished
Old Oct 2, 2001 | 05:02 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
the entire design is versitile. Bore size could be almost anything up to 2.25 without having to redesign the pod.
the injectors will be over the bores, because it utilized your stock pod. to save $. but since you could have 2.25" bores, the percentage of flow that they obstruct is lessened.
its a 3 peice design, completely simplified and VERY versitile to modify and change.
hopefully i have will have expendable $ after december. if not im gona make some wooden ones i think, so i can at least do quick tests of actual functionality. they will be tested on the 69's 307.
Old Oct 2, 2001 | 06:57 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
<font face="Verdana, Arial" size="2">the entire design is versitile. Bore size could be almost anything up to 2.25 without having to redesign the pod.
hopefully i have will have expendable $ after december. if not im gona make some wooden ones i think, so i can at least do quick tests of actual functionality. they will be tested on the 69's 307</font>
Its beyond Limbo now.
Old Oct 2, 2001 | 10:52 PM
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Sounds good. Think will a dual setup I'll be breathing in around 1500 cfm? I guess that's enough, lol.
Old Oct 3, 2001 | 08:53 AM
snflupigus's Avatar
um, ya 1500 is enough for almost anything.
92firebirdguy
Sep 1, 2016 07:53 AM
Glowsock
Sep 11, 2015 11:09 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
Glowsock
Sep 5, 2015 07:48 PM
