Holley 670 cfm TBI unit worth it?
Old Sep 24, 2001 | 11:41 PM
BahamutRS's Avatar
Ehh..what if I can get one for 100 bucks? Should I bother? And is it a simple bolt-on thing? I heard some need computer programming and whatnot.
1992 Camaro RS (Auto) 5.0L TBI
Performance mods
NOS (125 HP shot)
Dynomax cat-back exhaust
Hedman headers
K & N open element/ X-Stream lid
MSD 6A ignition
MSD 8.5mm plug wires
LT1 camshaft
Soon to be installed:
Edelbrock intake manifold
B & M 2400 RPM stall torque converter
Trans Go shift kit
World Products Torquer heads
Audio
Sony Xplod CDX-M610 head unit
Pioneer 2-way 4x6 front speakers
Pioneer 3-way 6x9 rear speakers
12 inch Pioneer VCCS PRO subwoofer
QLogic sealed box
Kicker ZR360 amplifier
Lightning Audio 1 farad capacitor
Other
Macewen White Faced Gauges/Shift overlay
A-pillar gauges (Phantom oil pressure, Air/Fuel)
180* thermostat
Window Tint
Old Sep 25, 2001 | 12:53 AM
TriGenRS's Avatar
Im no expert but here's what I think:
I would say that $100 is pretty much the going rate for a used Holley 670 TBI or used GM 454 TBI. You seem to have a good breathing engine except for the TBI unit. So i would say that you should go for it. You've been here a while so im guessing you already know about the injector quality stuff.
The stand alone unit is a simple bolt on....*IF* you get the adaptors that comes with the Holley.
There is a barrel reducer to (somewhat) smoothly reduce the 2" Holley barrels to the small bore 305 (forgot the size) barrels. The extra height the adaptor adds is minimal. The air cleaner will push into the sound deadener on the hood but not actaully touch the hood.
There is also a electrical connector for the injectors that you have install.
It shouldnt need reprogramming but due to the amount of your mods .... you might want to look into it.
89CamaroRS
Power Rating: 1.21 Jigowatts
Mods:Flux Capacitor
Future Plans: Time Travel
Old Sep 25, 2001 | 01:01 AM
BahamutRS's Avatar
I intend on getting a custom Ed Wright chip once I get all the stuff I have/want in.
Performance mods
NOS (125 HP shot)
Hedman headers
MSD 6A ignition
LT1 camshaft
Trans Go shift kit
Audio
QLogic sealed box
Other
180* thermostat
Window Tint
Old Oct 8, 2001 | 09:22 AM
92blackbird's Avatar
Car: 1992 pontiac firebird
Engine: 305 tbi
I got a used one off a 454 from a friend for $0. but I forget what year it was. I bored out the stock manifold for the 2" butterflys. All the rest bolted right up including all electronics. I don't see a hugh gain because the rest of the engine is still stock except the exhaust. Drivability is fine and when you floor it, it sounds like you'll suck the hood right thru the intake. The intake roar actually drowns out the exhaust note inside the car. But now the engine is ready for whatever other mods I want to do.
'92 firebird t-tops
305tbi,670cfm tbi, 2 1/2" Dynomax catback, 9x3 K&N open element
92camaroJoe
Jul 29, 2023 07:57 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
