DROP/NON-DROP BASE OPEN ELEMENT
Old Oct 8, 2001 | 06:35 PM
z28camaro396's Avatar
Which is better, a drop or non-drop base element? Also, I bought a K&N air filter to fit my stock air cleaner, will that fit under a 14x3 open element or not. Another question is, what to do about the black metal hose that connects to the stock air cleaner with the filter inside the air cleaner. Thanx for the help.
1988 305 TBI camaro. Flowmaster exhaust, K&N air filter, complete IROC-Z makeover (stripes, ground effects, interior...etc), Kenwood c.d. player, Sony Xplod 6x9's, Blaupunkt 3 1/2's.
Old Oct 8, 2001 | 06:39 PM
Tas's Avatar
Tas
stock k&n is way too small for a 14x3 open element.
https://www.thirdgen.org/messgboard/...ML/002566.html
https://www.thirdgen.org/messgboard/...ML/002561.html
https://www.thirdgen.org/messgboard/...ML/002492.html
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Got Beach?
[This message has been edited by Tas (edited October 08, 2001).]
Old Oct 9, 2001 | 12:57 PM
Am I correct that leaving the breather (small black hose with filter coming from the passenger's side valve cover, in my previous juvenile remark) is harmless as well as removing it completely and/or getting an aftermarket filter to plug it? Also, in regards to the coil wires-is that the wires in the TBI or under it or what exactly. Sorry for the lack of knowledge questions-just don't want to screw up the ride. Thanx.
Old Oct 9, 2001 | 08:58 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
get a non drop base, follow the directions on the tech article. there is a hose coming from the front of the tbi to the stock cleaner, remove it from the cleaner and stick a screw in it to plug it. the wires are the plug wires, the shouldn't be smashed under the cleaner, if they are, simply angle them out of the way, and don't let them rub each other. and the stock K&N, kiss it good bye, you have to buy another for the OE.
late model 91 rs, fully loaded, auto, t-tops, red leather, paint- gm red and yellow blend (light red), custom painted 16" Camaro rims
305 tbi flat base 14"x3" with K&N, hypertech chip, accel super stock plug wires, only use full synthetic oil and delco filter, 2 1/2" cat delete pipe, Edelbrock 3" cat-back
MTX sub and amp, Bose all around
vic_v8@yahoo.com
street kills: New v-6 stang, 96 v6 camaro, totally killed '86 SC Camaro (305), 91 z 28 with 305
15.854@87.57 (I think I could have it 15.5 with good tires and two more runs)
next month: rest of ultimate tbi
wigmobile
Feb 26, 2025 02:56 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
mrestrictrplate
Sep 21, 2015 11:24 AM
NiG
Sep 7, 2015 11:25 PM
luvofjah
Sep 3, 2015 07:08 PM
