Need a part# off an 89-92TBI 5-Speed car
Old Oct 7, 2001 | 11:36 AM
Blue91''s Avatar
Someone please help man, I need the part number or RPO code for the vehicle speed sensor in a factory TBI 5-Speed Cam/Bird 89-92. I swapped in a 5-speed and I cant find any info on getting the correct VSS.Any help would be greatly appreciated!!!! Thanks
Old Oct 8, 2001 | 08:57 PM
Blue91''s Avatar
I just need the part number thats stamped on the vehicle speed sensor from anyone with a T B I 5-speed car.
Old Oct 9, 2001 | 02:43 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I have a 92 RS,(was a 305),With T5 Trans.
My transmission is currently laying on the garage floor, so I went out and looked at it.
The number stamped on the speed sensor is:
10456087 7231
Hope that helps.
-Rich-
1992 RS,5 Speed,T-Tops,Eibach Springs(cut), KYB's, Lakewood Trailing Arms and Adjustable Panhard Bar,Posi Disc Rear,3.73 Gears,Summit Rearend Support Cover,
Del-A-Lum Bushings,300 HP Crate Motor,Crane Comp-U-Cam,Edelbrock TBI Intake, Turbo City Ported Throttle Body and Adjustable Fuel Pressure Regulator,Open Element
Air Cleaner, Ground Control Strut Tower Brace and Caster/Camber Adjusters,SLP 1-5/8" Headers,Flowmaster 3" American Thunder Exhaust,3" Cat,Centerforce Dual
Friction Clutch,Hayes Billet Flywheel,B&M Power Steering Cooler,Big Thumpin' Stereo.
Old Oct 9, 2001 | 09:35 PM
Blue91''s Avatar
Thanks rich, thats the info I needed.I appreciate it, you wouldnt be able to tell me what color the speedo gears are by any chance? The ones I supposedly have are from a 308 rear geared car as well.I also have the same sensor and it throws a code, I guess I got a bad sensor.
[This message has been edited by Blue91' (edited October 09, 2001).]
Old Oct 11, 2001 | 03:16 PM
CODY BEHNKE's Avatar
The best way to tell is to count the teeth on both gears because I think there is two of the same color but one has less teeth.
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
