TB WON'T PRIME ON STARTUP
Old Oct 4, 2001 | 10:14 PM
simon's Avatar
It's been slightly difficult to start my LO3 lately and it occasionally stalls at lights. I noticed that the TB isn't spraying when I turn the key to "run". Aren't the injectors supposed to spray prior to startup? I rebuilt the injectors about 8 mos ago so they should be fine. When the car eventually starts the spray pattern is appropriately conical. I also replaced the fuel filter within the past 8 mos. The only thing I can think of is may be the battery isn't putting out enough power but it cranks the engine just fine so that can't be it. Oh, I also replaced the fuel pump relay as well - same problem. What I don't get is eventually the injectors must fire or it wouldn't start. Any ideas as to what's going on?
89 RS V8,Borg-Warner 9-Bolt rear,Open element,Flowmaster.
Old Oct 4, 2001 | 11:29 PM
Andy89RS's Avatar
The injectors are not supposed to fire until the engine is actually turning over. Firing them when the key is in the "on" position but the engine is not running would be a great way to flood the engine.
Member Southern California 3rd Generation F Bodies
Co-President Golden State 3rdgens
AOL IM: Andy89RS
Old Oct 5, 2001 | 12:13 AM
simon's Avatar
So the engine doesn't get a shot of fuel fromt the TB prior to startup? In the past I could have sworn I saw it spray at the same time I heard the pump prime prior to startup.
Old Oct 5, 2001 | 07:42 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
The pump primes in order to build up pressure. You shouldn't see fuel leaving the injectors until the engine actually cranks. If you do the you have leaky injectors
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old Oct 10, 2001 | 04:01 AM
4-bolt's Avatar
Your fuel system may be letting the fuel run back into the tank. When it dies at red lights, does it start right back up, or does it take awhile? There is a check valve in the fuel pump that keeps the fuel from running back into the tank. Just a tip from my experiences never rule out anything because it is only so and so old. I have had brand new parts that were worse than the broken parts that were taken off.
'87 Silverado
350 4 bolt main bore .040 over
TB Injected
Ported and Polished heads
Comp cams 268h cam and top end
Flowtech headers
3.73s on Detroit locker
Old Oct 11, 2001 | 04:18 PM
simon's Avatar
It starts right back up - what could be causing the check valve to do this?
RS Reaper
Oct 17, 2018 07:52 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
the_hamturdler
Sep 30, 2015 12:50 PM
