TBI unit rebuilt kit
Old Apr 23, 2007 | 05:26 PM
wahoo's Avatar
Car: Camaro RS 1992
Engine: 305 TBI
Transmission: TH700R4
Hi,
Last week end, I looked at the engine of my RS cause, there's a fuel odor that seems to come from the TBI unit. And I have seen what it seems to be a fuel leak. So I think it's time to rebuilt the TBI unit.
Question : can you advise me a rebuild kit for my TBI unit. Where to buy it?
I've read the CHP article : Blueprint for success
But there are some details I don't want to do. I don't want to improve the TBI unit, I just want to stop the fuel leak.
Maybe it could be interesting to put an adjustable FPR and bigger injectors. what do you think?
Old Apr 24, 2007 | 08:23 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: TBI unit rebuilt kit
Wahoo
I think the reason why you did not get any responses is because most of us do not know what part suppliers available in French auto parts stores! Probably very little for your 305 RS!
In USA there are many suppliers, but most of them OEM from a handful of companies.
For your car ’92 TBI:
Niehoff rebuild kit
http://www.niehoff.com/catalogs/nie_bgbulk.aspx?strSearch=CK1081
Wells rebuild kit
http://www.e-webcatalog.com/wells/ecatalog.aspx
Part Number CK883
Where is your fuel leak? You got to fix it ASAP – or you can loose your car to an engine fire!!!
Adjustable FPR and bigger injectors will not add any value unless you improve engine breathing as well – restricted exhaust system is the first thing that should be looked at before even contemplating above mentioned items. See sticky in TBI forum.
//RF
Old Apr 25, 2007 | 10:16 AM
wahoo's Avatar
Car: Camaro RS 1992
Engine: 305 TBI
Thanks for your reply.
There's no chance to find a rebuilt kit for my TBI unit cause the third gen are unknown in France.
I always order my parts in United States, (summit, jegs, ebay.com, and so on). It's very easy to order online with nternet and parts are cheaper in US than in France.
Thanks for the links for the rebuilt kit.
For the injectors and the AFPR, I know that on a stock engine, it's not very useful. But I plan to put, in a delay of 6 months to one year, some vortec heads, intake manifold, camshaft, and headers. I don't know if it's very useful to put another TBI unit.
But if I keep the stock one, it could be useful to improve it now, no?
Old Apr 25, 2007 | 10:19 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Let me guess, your fuel leak is coming from hmmm the fuel return line ?
Old Apr 25, 2007 | 10:40 AM
wahoo's Avatar
Car: Camaro RS 1992
Engine: 305 TBI
No I don't think so.
If I remember me, I ve seen a trace on the side of the throttle body... Overflow? I will inspect it this week end, and I will tell you.
Can you confirm me that I can start and run the engine without the air filter, just to see how the TBI unit works and where's the problem?
Old Apr 25, 2007 | 01:27 PM
RFmaster's Avatar
Car: 75 Beast
Yep, you can start her up without air cleaner...
Old Apr 26, 2007 | 04:53 PM
blizzted's Avatar
Car: 2000 tahoe,94 ex-cab,92 rs
Engine: 350,350,305
Transmission: all autos
tbi rebuild i dont know if this will help or not but i just rebuilt mine got the kit from oreilly it was like 35 bucks and it came with all gaskets and orings your leak is more than likely coming from the diaprham in the back those always wear out if you know someone here in the states get them to send you the kit or heck if you need it that bad and dont know anyone send me the money and i will mail you one always try to help out...Steve
Old Apr 27, 2007 | 04:37 PM
wahoo's Avatar
Car: Camaro RS 1992
Engine: 305 TBI
Thanks to help me<img>
If I need your help, be sure I won't hesitate<img>
Old Apr 28, 2007 | 09:36 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Ya know I was trying to find a rebuild kit for my TBI under $15. I know this sounds crazy because a lot has happened in two years since my last rebuild but the last time I bought one it was $9.95 for everything that was in the kits listed in the first post above. Is $35 the cheapest anyone has seen?
Old May 5, 2007 | 07:35 AM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
Autozone keeps rebuild kits for them...(dont go in there and ask for one.. they will look at u like your stupid and be able to find it)But I have a part number you can get it with...try this link http://autozone.com/R,APP766768/vehi...ductDetail.htm this kit includes everything exept the fpr diaphram..it has the gasket though so you can remove the fpr and put it back on.....hope this helps...oh the $35 one has the diaphram and thats the only differance...
Old May 5, 2007 | 05:06 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
This link won't work for me. Do you have a part number I can look up at AutoZone? By the way what part of Tennessee are you from? I lived near Chattanooga before going to the Air Force.
Old May 5, 2007 | 05:34 PM
dwillis's Avatar
Axle/Gears: 3:08
I live in Jackson...Its between memphis and nashville......the part# is
96-3013a
Old May 6, 2007 | 08:26 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Small world! Hey thanks for the info.
Old May 6, 2007 | 09:39 PM
dwillis's Avatar
Axle/Gears: 3:08
No prob man...
hectre13
Dec 11, 2023 08:14 AM
92camaroJoe
Jul 29, 2023 07:57 PM
hectre13
Aug 26, 2015 08:17 AM
92camaroJoe
Aug 13, 2015 06:07 AM
