fuel issue help needed asap
Old Apr 23, 2007 | 06:31 PM
speedped79's Avatar
Car: 1982 z28
its a 1991 camaro rs tbi.
went to start the car and it was hard to start but started, idles for a few mins and died and wouldnt start. i traced the problem to the fuel pump not coming on. i used the test wire and the pump just clicked and wouldnt go on, so i replaced it.......ok, weird issue here im thinking electrical.
1. if you turn the key you CANNOT hear the pump go on and it will not start
2.if you run power to the test wire the pump WILL go on but the car still WILL NOT start
what can this possibly be?
pumps new. relays new. when i use the test wire and the pump runs i can feel fuel going thru the lines by the throttle body but the injecters just arent supplying the fuel.
HELP!!!!
thanks steve
Old Apr 23, 2007 | 06:38 PM
wahoo's Avatar
Car: Camaro RS 1992
Engine: 305 TBI
Transmission: TH700R4
Re: fuel issue help needed asap
VATS maybe?
Old Apr 23, 2007 | 06:43 PM
speedped79's Avatar
Car: 1982 z28
whats the vats system do? and how could i check this?
Old Apr 23, 2007 | 09:28 PM
speedped79's Avatar
Car: 1982 z28
also i tryed dumping a small amount of fuel in the throttle body and it ran for a second and then died
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
IROCZ1989
Jan 24, 2016 03:55 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
