Backfireing??
Old Apr 28, 2007 | 12:00 PM
90c350's Avatar
Backfireing??
Hey just a quick question. After doing my 305 to 350 swap the engine is running and idle pretty good but it has a miss/backfire through the tbi when I hit the gas hard in any gear and when in neutral as well. If its cold and rev it it does not do it but after a minute or two it will start to do the same thing. It seems to get worse the hotter the engine gets. Any help would be appreciated. THANKS
Old Apr 28, 2007 | 01:10 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Re: Backfireing??
Sounds like it's running rich. Have the timing checked. Have you given it a good tune up?(plugs,wires, cap).
Have you checked the resistance on each injector to make sure they are working properly?
Old Apr 28, 2007 | 03:46 PM
90c350's Avatar
Re: Backfireing??
Plugs/wires/cap & rotor are all new. New MSD wires and ignition coil. New engine just broken in on a carb, then swapped over to tbi from a different truck. I have not checked the injectors but they ran good on My freinds truck, that I stole them off of. I do have an afpr but havent been able to get a guage hooked up Yet. I thought that a backfire through the carb was generally caused by a lean condition. It will do it when worm at almost any rpm if I hammer on it!! Any more suggestions that I can do this weekend Until I get back to work would be Great!!! Thanks alot
Old Apr 28, 2007 | 09:41 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Backfireing??
It sounds like its running lean or is lean during hard accel. This can only really be fixed by tuning.
tyeo098
Nov 30, 2015 06:27 PM
racereese
Oct 3, 2015 03:46 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
Racerx974
Sep 19, 2015 10:16 AM
