Fast Idle/high IAC
Old Oct 31, 2001 | 07:40 PM
1sick57's Avatar
Fast Idle/high IAC
Has anyone had this problem? When in gear, and stopped, my idle air counts gradually increase until maxed out at 145. Also when driving the ecm sets a code 32, although I have a new egr valve and switch. Everything I have checked seems ok, so I'm mystified. Anyone got any ideas?
Regards, Greg Mann
Old Nov 1, 2001 | 01:29 PM
z28camaro396's Avatar
If i'm not mistaken...i believe a code 32 is the CTS (Coolant Temp. Sensor). I had this problem and a new temp. sensor fixed it. Cheap replacement too. Hope this helps somewhat.
1988 305 TBI camaro. Flowmaster exhaust, 14x3 open air element, complete IROC-Z makeover (stripes, ground effects, interior...etc), Kenwood c.d. player, Sony Xplod 6x9's, Blaupunkt 3 1/2's.
Old Nov 1, 2001 | 02:27 PM
Fish89's Avatar
Car: 89 Camaro
Engine: 97 LT1
Axle/Gears: 323 Posi
Code 32 is for the EGR not the Coolant temp sensor. I would just double check everything again make sure it's not sticking. Did you reset the computer?
Old Nov 1, 2001 | 07:42 PM
1sick57's Avatar
I've replaced the ecm,prom,egr valve,egr vacuum switch, IAC motor,oxygen sensor,smog pump, and fuel filter. I've checked all the wiring, the temp sensor, the TPS sensor, and the injectors. The only thing that doesn't check out is it has low intake vacuum, although the engine runs great. I'm stumped, there is something in the programming of the ecm which causes increased idle counts under certain conditions, I just wish I knew what they were.
Regards, Greg Mann
InfernalVortex
Apr 20, 2021 11:31 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
greenyone
Sep 2, 2015 03:39 PM
